RockPro64 Official Kernel Support
(08-20-2019, 01:39 PM)rocksa Wrote: System does not boot
I don't know what else to do
The problem 99% is at uboot.
PLEASE HELP ME
Hello rocksa,
I don't know if I can help you..
Because I have not all info, and its a lot of it .. Sad
A Lot changed since 4.4.X series..and also I have not yet build my kernel..
You need o "deeper" .config file for sure..
make menuconfig
With this step, after clean, and make 'defconfig_boardname' ...
But first you need to clean it..
issue:
make -h
It will give you all options  Undecided
find the board 'defconfig' file
The initial sequence..
Quote:make clean
make defconfig_board_name
make menuconfig
RockChip uses a different scheme for the bootloader..
I am not there yet, still coding my CI pipeline( then I need to  glue it all together.. ).. Sad
What tells you the file:
cat /boot/efi/extlinux/extlinux.conf
# also
ls -la /{,boot}
adjust 'extlinux.conf' file for your needs..
Do you sure the modules are in '/lib/modules/$(uname -r)/kernel'
tree -L 3 /lib/modules/$(uname -r)/kernel
find /lib/modules/$(uname -r) -name \*.ko -exec ls -ltr {} \;
Regards,
RockPro64 Official Kernel Support - by ASIC - 10-31-2018, 09:15 AM
RE: RockPro64 Official Kernel Support - by tllim - 11-06-2018, 10:00 PM
RE: RockPro64 Official Kernel Support - by tuxd3v - 11-09-2018, 04:46 PM
RE: RockPro64 Official Kernel Support - by fosf0r - 04-11-2019, 01:10 PM
RE: RockPro64 Official Kernel Support - by mjog - 07-12-2019, 12:34 AM
RE: RockPro64 Official Kernel Support - by Luke - 07-12-2019, 08:33 AM
RE: RockPro64 Official Kernel Support - by tuxd3v - 08-09-2019, 01:19 PM
RE: RockPro64 Official Kernel Support - by rocksa - 07-30-2019, 05:31 PM
RE: RockPro64 Official Kernel Support - by rocksa - 08-06-2019, 11:35 AM
RE: RockPro64 Official Kernel Support - by rocksa - 08-20-2019, 01:39 PM
RE: RockPro64 Official Kernel Support - by tuxd3v - 08-20-2019, 05:43 PM
RE: RockPro64 Official Kernel Support - by rocksa - 08-21-2019, 01:26 AM
RE: RockPro64 Official Kernel Support - by tuxd3v - 08-21-2019, 08:56 AM
RE: RockPro64 Official Kernel Support - by rocksa - 08-22-2019, 07:36 PM
RE: RockPro64 Official Kernel Support - by tuxd3v - 08-22-2019, 10:32 PM
RE: RockPro64 Official Kernel Support - by rocksa - 08-23-2019, 02:28 AM
RE: RockPro64 Official Kernel Support - by tuxd3v - 08-29-2019, 05:39 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 9 16,607 10-31-2025, 06:33 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 137,097 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,077 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 3,294 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 6,764 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 3,937 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,473 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 110,680 08-11-2023, 11:13 AM
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 4,152 06-16-2023, 10:54 AM
Last Post: CounterPillow
  How to enable CoreSight ETM trace on RockPro64 shpark 0 2,771 05-21-2023, 11:34 PM
Last Post: shpark
