power Circuit
#22
(04-12-2016, 07:54 PM)faddah Wrote:
(04-12-2016, 04:29 PM)SkairkrohBule Wrote: Best to just solder it, if you are sure you want the power/reset switch mounted on the board like that. Bending the legs into place will never provide the secure connection you'll get from soldering. Besides, soldering is fun!
If you are scared to solder direct to the board, for fear of messing something up, you can still gain the functionality of power and reset switches by using the EXT series of connections (Page 3 of this).
Just buy some DuPont wires and solder a switch to those. That way you don't need to solder direct to the board.
hi @SkairkrohBule,
thanx for the info.
i don't know enough EE to read those pin-outs and find a now-out-of-business radio shack or the like to get the wires and the switch, so i just went to ebay and purchased a nice $9/free shipping soldering kit. i'll give it a go when it arrives in a few days. much thanx!
best,
—  faddah
     portland, oregon, u.s.a.
Ok, cool. There are plenty of soldering tips and tricks on eBay. Basic ones are to:
Tin the tip of the soldering iron
Wipe down on sponge or similar between uses to remove excess
Touch both surfaces (in this case, the prong of the switch leg and the metal ring of the hole in the Pine64 board) at the same time to heat them up to the same temperature before applying solder (heating just the switch leg or just the metal ring won't help anyone, both surfaces need to be hot for the solder to bridge the gap and flow between them)
And: don't hold the soldering iron to the printed circuit board for too long. Metal traces heat up quite quickly and you can cause damage to the board if you just hold it there for ages.
So, summary: get the soldering iron tip hot, tin it, hold to the join (switch leg and pcb ring), apply solder, remove soldering iron tip and wait for solder to set.
power Circuit - by polo - 12-24-2015, 06:37 AM
RE: power Circuit - by tllim - 12-24-2015, 05:57 PM
RE: power Circuit - by Nilocsemliw - 01-28-2016, 01:08 PM
RE: power Circuit - by tllim - 01-28-2016, 04:04 PM
RE: power Circuit - by Nilocsemliw - 01-28-2016, 05:44 PM
RE: power Circuit - by SkimMilk - 01-28-2016, 05:56 PM
RE: power Circuit - by tllim - 01-28-2016, 07:39 PM
RE: power Circuit - by Nilocsemliw - 01-28-2016, 11:41 PM
RE: power Circuit - by Ghost - 01-29-2016, 05:55 AM
RE: power Circuit - by SkimMilk - 01-28-2016, 10:38 PM
RE: power Circuit - by Gearsoul - 01-29-2016, 01:56 AM
RE: power Circuit - by SkimMilk - 01-31-2016, 11:49 PM
RE: power Circuit - by Ghost - 02-03-2016, 06:00 PM
RE: power Circuit - by SkimMilk - 02-03-2016, 06:17 PM
RE: power Circuit - by 1q84 - 03-14-2016, 09:41 PM
RE: power Circuit - by tllim - 03-15-2016, 09:13 AM
RE: power Circuit - by 1q84 - 03-15-2016, 01:30 PM
RE: power Circuit - by tllim - 03-15-2016, 04:14 PM
RE: power Circuit - by crash042 - 06-21-2016, 11:57 AM
RE: power Circuit - by SkimMilk - 06-21-2016, 12:04 PM
RE: power Circuit - by Topgun505 - 07-01-2016, 07:23 AM
RE: power Circuit - by faddah - 04-12-2016, 02:37 PM
RE: power Circuit - by Ghost - 04-12-2016, 04:29 PM
RE: power Circuit - by faddah - 04-12-2016, 07:54 PM
RE: power Circuit - by Ghost - 04-12-2016, 08:06 PM
RE: power Circuit - by faddah - 04-13-2016, 07:51 AM
RE: power Circuit - by Ghost - 04-16-2016, 06:30 PM
power Circuit - by SkimMilk - 07-01-2016, 08:56 AM
RE: power Circuit - by pfeerick - 07-01-2016, 07:06 PM
  Z-Wave - Full and Low Power Inclusion mode B34N 1 4,300 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 4,517 01-22-2017, 01:32 PM
Last Post: Luke
  Low power headless operation? rubenk 9 15,483 01-05-2017, 12:37 AM
Last Post: swinging
  Power switch circuit drewh 43 64,086 09-19-2016, 09:17 AM
Last Post: tampadave
  Power Off / Reset Buttons - DietPi casmiguefl 4 8,370 08-12-2016, 05:28 PM
Last Post: casmiguefl
  Power over Ethernet (PoE) WLR 1 5,864 02-10-2016, 07:14 PM
  USB HDD Power eender 5 9,576 02-06-2016, 09:30 PM
Last Post: blktiger
