power Circuit
(03-15-2016, 01:30 PM)1q84 Wrote:
(03-15-2016, 09:13 AM)tllim Wrote:
(03-14-2016, 09:41 PM)1q84 Wrote:
(01-31-2016, 11:49 PM)SkimMilk Wrote: Hi all,
I'm looking for the switch that tllim posted at this website:
http://sg.element14.com
I'm not electronics trained, so it's kind of hard finding it.
Can anyone advise what keyword I should be searching for?
https://www.amazon.ca/gp/product/B00TX40...UTF8&psc=1
 or this type below. I saw a picture here at the pine 64 forum where someone soldered a similar two pin type to their board
https://www.amazon.ca/gp/product/B00EDJY...UTF8&psc=1
I live in Canada but they can probably all be found at amazon.com or ebay
(01-28-2016, 11:41 PM)Nilocsemliw Wrote:
(01-28-2016, 07:39 PM)tllim Wrote:
That is correct.
I am sorry I can't read Chinese characters. Could we wire the switch around 4 feet away from the board than?
You could probably use a PC ATX on/off switch. You would need to solder the male connector to the board. I have been looking for one but no luck so far. It should work as long as it fits. Maybe the devs can point us in the right direction? Smile
http://www.ebay.com/itm/10x-PC-ATX-Power...1810341430
You can plug this cable at the EXT connector for reste and power on functions, please check pin definition on wiki page. When we define the EXT connector pin layout, we have factor in such cable combination.
Hi Tllim,
After I replied to the previous message I found a thread on power through GPIO with a  pdf of the pine 64 pin assignment and I noticed this on page 3 where the ext connector layout is listed.  Based on the information in the pdf it looks like pin 5 is the pwr switch and the cables are two pin so I am assuming that pin 6 is the ground for this connection. I take it the reset switch would also share the same ground?
yes
power Circuit - by polo - 12-24-2015, 06:37 AM
RE: power Circuit - by tllim - 12-24-2015, 05:57 PM
RE: power Circuit - by Nilocsemliw - 01-28-2016, 01:08 PM
RE: power Circuit - by tllim - 01-28-2016, 04:04 PM
RE: power Circuit - by Nilocsemliw - 01-28-2016, 05:44 PM
RE: power Circuit - by SkimMilk - 01-28-2016, 05:56 PM
RE: power Circuit - by tllim - 01-28-2016, 07:39 PM
RE: power Circuit - by Nilocsemliw - 01-28-2016, 11:41 PM
RE: power Circuit - by Ghost - 01-29-2016, 05:55 AM
RE: power Circuit - by SkimMilk - 01-28-2016, 10:38 PM
RE: power Circuit - by Gearsoul - 01-29-2016, 01:56 AM
RE: power Circuit - by SkimMilk - 01-31-2016, 11:49 PM
RE: power Circuit - by Ghost - 02-03-2016, 06:00 PM
RE: power Circuit - by SkimMilk - 02-03-2016, 06:17 PM
RE: power Circuit - by 1q84 - 03-14-2016, 09:41 PM
RE: power Circuit - by tllim - 03-15-2016, 09:13 AM
RE: power Circuit - by 1q84 - 03-15-2016, 01:30 PM
RE: power Circuit - by tllim - 03-15-2016, 04:14 PM
RE: power Circuit - by crash042 - 06-21-2016, 11:57 AM
RE: power Circuit - by SkimMilk - 06-21-2016, 12:04 PM
RE: power Circuit - by Topgun505 - 07-01-2016, 07:23 AM
RE: power Circuit - by faddah - 04-12-2016, 02:37 PM
RE: power Circuit - by Ghost - 04-12-2016, 04:29 PM
RE: power Circuit - by faddah - 04-12-2016, 07:54 PM
RE: power Circuit - by Ghost - 04-12-2016, 08:06 PM
RE: power Circuit - by faddah - 04-13-2016, 07:51 AM
RE: power Circuit - by Ghost - 04-16-2016, 06:30 PM
power Circuit - by SkimMilk - 07-01-2016, 08:56 AM
RE: power Circuit - by pfeerick - 07-01-2016, 07:06 PM
  Z-Wave - Full and Low Power Inclusion mode B34N 1 4,313 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 4,526 01-22-2017, 01:32 PM
Last Post: Luke
  Low power headless operation? rubenk 9 15,526 01-05-2017, 12:37 AM
Last Post: swinging
  Power switch circuit drewh 43 64,349 09-19-2016, 09:17 AM
Last Post: tampadave
  Power Off / Reset Buttons - DietPi casmiguefl 4 8,409 08-12-2016, 05:28 PM
Last Post: casmiguefl
  Power over Ethernet (PoE) WLR 1 5,877 02-10-2016, 07:14 PM
  USB HDD Power eender 5 9,627 02-06-2016, 09:30 PM
Last Post: blktiger
