Slow ethernet in linux
(04-28-2016, 09:45 AM)tkaiser Wrote:
(04-23-2016, 03:11 PM)baryluk Wrote: made me able to copy data over ssh from other Linux box (capable of easily doing 100MB/s), with about 22MB/s (tested using 1.2GB file using dd bs=64k from sshfs file)
So you did not test network speed but CPU encryption performance instead. Why exactly?
to test the actual speed, i would rather use speedtest_cli
sudo wget https://raw.github.com/sivel/speedtest-cli/master/speedtest_cli.py
sudo chmod a+rx speedtest_cli.py
./speedtest-cli
where i have 2Mbit/s, which, for some reason is 2-4x more than any wget command (60-120kb/s)
on the other host, speedtest result is 120Mbit/s  Angry
Slow ethernet in linux - by dipole - 04-17-2016, 08:32 AM
RE: Slow ethernet in linux - by androsch - 04-17-2016, 08:50 AM
RE: Slow ethernet in linux - by dipole - 04-17-2016, 09:04 AM
RE: Slow ethernet in linux - by may1791 - 04-17-2016, 03:18 PM
RE: Slow ethernet in linux - by coleshores - 04-18-2016, 09:40 AM
RE: Slow ethernet in linux - by Sailing_Nut - 04-22-2016, 01:53 PM
RE: Slow ethernet in linux - by patrickhwood - 04-22-2016, 09:06 PM
RE: Slow ethernet in linux - by androsch - 04-22-2016, 04:25 PM
RE: Slow ethernet in linux - by Sailing_Nut - 04-22-2016, 07:13 PM
RE: Slow ethernet in linux - by androsch - 04-23-2016, 01:15 AM
RE: Slow ethernet in linux - by baryluk - 04-23-2016, 03:11 PM
RE: Slow ethernet in linux - by piahoo - 04-28-2016, 09:03 AM
RE: Slow ethernet in linux - by tkaiser - 04-28-2016, 09:45 AM
RE: Slow ethernet in linux - by piahoo - 04-28-2016, 12:55 PM
RE: Slow ethernet in linux - by tkaiser - 04-28-2016, 01:02 PM
RE: Slow ethernet in linux - by baryluk - 04-28-2016, 04:15 PM
RE: Slow ethernet in linux - by ak_hepcat - 04-29-2016, 12:41 PM
RE: Slow ethernet in linux - by longsleep - 04-29-2016, 01:03 PM
RE: Slow ethernet in linux - by ak_hepcat - 04-29-2016, 02:21 PM
RE: Slow ethernet in linux - by baryluk - 05-01-2016, 01:27 PM
RE: Slow ethernet in linux - by ak_hepcat - 05-04-2016, 01:40 PM
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 14,338 03-28-2020, 06:20 PM
Last Post: ty1911
  Howto run Linux with resolution other than 1080p longsleep 28 83,027 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 8,008 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 12,517 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 61,932 01-28-2019, 11:05 PM
Last Post: necrose99
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,046 12-06-2018, 01:14 AM
Last Post: tenspd137
  Real-time linux kernel Artyom 45 101,250 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 8,654 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 7,795 01-30-2018, 10:26 AM
Last Post: Rustproof
  eta linux image?? firosiro 1 5,688 08-03-2017, 10:05 PM
Last Post: pfeerick
