PCIe Inconsistency Problems
(10-24-2018, 11:52 PM)jannerman Wrote: I can confirm jja2000 problem on 0.79.
Without HDD connected lspci works fine and it shows ASMEDIA.
If you connect the HDD it works fine (doesn't freeze), you can access HDD and lspci works properly.
If you load LXDE or Openbox system freezes.
Looks like an software problem!?
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
PCIe Inconsistency Problems - by jja2000 - 10-21-2018, 06:39 AM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-21-2018, 11:29 AM
RE: PCIe Inconsistency Problems - by jja2000 - 10-22-2018, 10:48 AM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-22-2018, 11:06 AM
RE: PCIe Inconsistency Problems - by jja2000 - 10-22-2018, 11:11 AM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-22-2018, 11:23 AM
RE: PCIe Inconsistency Problems - by jja2000 - 10-22-2018, 01:27 PM
RE: PCIe Inconsistency Problems - by jannerman - 10-22-2018, 02:19 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-22-2018, 09:22 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-23-2018, 12:31 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-23-2018, 12:32 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-23-2018, 12:35 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-23-2018, 12:54 PM
RE: PCIe Inconsistency Problems - by jannerman - 10-24-2018, 11:52 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-29-2018, 01:16 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-29-2018, 02:12 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-29-2018, 02:49 PM
RE: PCIe Inconsistency Problems - by TheHunter - 11-16-2018, 06:07 PM
RE: PCIe Inconsistency Problems - by jja2000 - 12-17-2018, 01:39 PM
  RK3399 PCIe enumeration jhadd 0 292 01-31-2024, 08:56 AM
Last Post: jhadd
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 2,248 10-14-2022, 06:24 AM
Last Post: rwk-
  No PCIe controller detected... Limhes 1 1,614 11-23-2021, 06:23 AM
Last Post: Limhes
  Using the PCIe slot of ROCKPro64 as EndPoint mode nonoriri 1 1,854 11-20-2021, 10:53 AM
Last Post: fire219
  WiFi not working with PCIe SSD installed mikeD 0 1,419 05-25-2021, 07:48 AM
Last Post: mikeD
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 6,887 05-20-2021, 10:04 PM
Last Post: t4_4t
  Problems with my RockPro64 tuxd3v 0 1,917 08-19-2020, 11:47 AM
Last Post: tuxd3v
  Frequent kernel panic, possibly due to PCIe SSD? meier 4 5,980 11-22-2019, 05:15 PM
Last Post: meier
  My PCIe disk controller works with Linux 5.3.6 guannais 1 2,766 10-30-2019, 07:11 PM
Last Post: guannais
Information Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D Luke 100 127,469 10-04-2019, 08:57 PM
Last Post: tuxd3v
