PCIe Inconsistency Problems
I can confirm jja2000 problem on 0.79.
Without HDD connected lspci works fine and it shows ASMEDIA.
If you connect the HDD it works fine (doesn't freeze), you can access HDD and lspci works properly.
If you load LXDE or Openbox system freezes.
PCIe Inconsistency Problems - by jja2000 - 10-21-2018, 06:39 AM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-21-2018, 11:29 AM
RE: PCIe Inconsistency Problems - by jja2000 - 10-22-2018, 10:48 AM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-22-2018, 11:06 AM
RE: PCIe Inconsistency Problems - by jja2000 - 10-22-2018, 11:11 AM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-22-2018, 11:23 AM
RE: PCIe Inconsistency Problems - by jja2000 - 10-22-2018, 01:27 PM
RE: PCIe Inconsistency Problems - by jannerman - 10-22-2018, 02:19 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-22-2018, 09:22 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-23-2018, 12:31 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-23-2018, 12:32 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-23-2018, 12:35 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-23-2018, 12:54 PM
RE: PCIe Inconsistency Problems - by jannerman - 10-24-2018, 11:52 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-29-2018, 01:16 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-29-2018, 02:12 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-29-2018, 02:49 PM
RE: PCIe Inconsistency Problems - by TheHunter - 11-16-2018, 06:07 PM
RE: PCIe Inconsistency Problems - by jja2000 - 12-17-2018, 01:39 PM
  RK3399 PCIe enumeration jhadd 0 300 01-31-2024, 08:56 AM
Last Post: jhadd
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 2,268 10-14-2022, 06:24 AM
Last Post: rwk-
  No PCIe controller detected... Limhes 1 1,623 11-23-2021, 06:23 AM
Last Post: Limhes
  Using the PCIe slot of ROCKPro64 as EndPoint mode nonoriri 1 1,863 11-20-2021, 10:53 AM
Last Post: fire219
  WiFi not working with PCIe SSD installed mikeD 0 1,427 05-25-2021, 07:48 AM
Last Post: mikeD
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 6,926 05-20-2021, 10:04 PM
Last Post: t4_4t
  Problems with my RockPro64 tuxd3v 0 1,922 08-19-2020, 11:47 AM
Last Post: tuxd3v
  Frequent kernel panic, possibly due to PCIe SSD? meier 4 6,021 11-22-2019, 05:15 PM
Last Post: meier
  My PCIe disk controller works with Linux 5.3.6 guannais 1 2,788 10-30-2019, 07:11 PM
Last Post: guannais
Information Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D Luke 100 127,873 10-04-2019, 08:57 PM
Last Post: tuxd3v
