PCIe Inconsistency Problems
Exactly the same problem (I have post same symptoms on another topic).
Reboot the device
DONT LOGIN
press ctrl+alt+f1 to bring the terminal.
Login and mount your hdd. You can also check your hdd with a smartctl to see if you can read its properties.
You should be ok.
After that if you try to login to lxde the board will hang again. But at least you will know that the PCIe and the harddisk works ok.
It's a software problem for sure.
PCIe Inconsistency Problems - by jja2000 - 10-21-2018, 06:39 AM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-21-2018, 11:29 AM
RE: PCIe Inconsistency Problems - by jja2000 - 10-22-2018, 10:48 AM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-22-2018, 11:06 AM
RE: PCIe Inconsistency Problems - by jja2000 - 10-22-2018, 11:11 AM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-22-2018, 11:23 AM
RE: PCIe Inconsistency Problems - by jja2000 - 10-22-2018, 01:27 PM
RE: PCIe Inconsistency Problems - by jannerman - 10-22-2018, 02:19 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-22-2018, 09:22 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-23-2018, 12:31 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-23-2018, 12:32 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-23-2018, 12:35 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-23-2018, 12:54 PM
RE: PCIe Inconsistency Problems - by jannerman - 10-24-2018, 11:52 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-29-2018, 01:16 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-29-2018, 02:12 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-29-2018, 02:49 PM
RE: PCIe Inconsistency Problems - by TheHunter - 11-16-2018, 06:07 PM
RE: PCIe Inconsistency Problems - by jja2000 - 12-17-2018, 01:39 PM
  RK3399 PCIe enumeration jhadd 0 320 01-31-2024, 08:56 AM
Last Post: jhadd
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 2,303 10-14-2022, 06:24 AM
Last Post: rwk-
  No PCIe controller detected... Limhes 1 1,650 11-23-2021, 06:23 AM
Last Post: Limhes
  Using the PCIe slot of ROCKPro64 as EndPoint mode nonoriri 1 1,886 11-20-2021, 10:53 AM
Last Post: fire219
  WiFi not working with PCIe SSD installed mikeD 0 1,438 05-25-2021, 07:48 AM
Last Post: mikeD
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 7,002 05-20-2021, 10:04 PM
Last Post: t4_4t
  Problems with my RockPro64 tuxd3v 0 1,935 08-19-2020, 11:47 AM
Last Post: tuxd3v
  Frequent kernel panic, possibly due to PCIe SSD? meier 4 6,061 11-22-2019, 05:15 PM
Last Post: meier
  My PCIe disk controller works with Linux 5.3.6 guannais 1 2,803 10-30-2019, 07:11 PM
Last Post: guannais
Information Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D Luke 100 128,517 10-04-2019, 08:57 PM
Last Post: tuxd3v
