ANNOUNCING RECALBOX FOR THE ROCKPRO64 - ALPHA RELEASE
(10-29-2018, 06:55 PM)Pitcrawler Wrote: I do have an issue to report. I was so close to having it just as I wanted it but this one seems to be a showstopper for me right now.
I know that the audio jack doesn't work on Linux right now, only HDMI audio. I have my RockPro64 connected to a monitor, so I'm using a HDMI to VGA adapter which also splits off the HDMI audio to a 3.5mm jack. Connected to that jack I have a set of speakers.
The issue is that within Recalbox the HDMI audio is either turned off or at 100% volume, with no in-between. The volume control does not work at all. It remains at 0% no matter what I try to change it to, but the actual volume output is always 100%. So now I can't have sound through those speakers because it's too loud. The speakers themselves have no in-built volume control. I tried looking at the config files and amixer, but there seems to be noting there either.
If you go into Kodi, that does have its own volume control that works just fine. It's just on Recalbox/Emulationstation where it doesn't work.
Thank you for letting me know! Can you confirm that if you plug directly to an HDMI tv with sound if the audio settings work for you? Want to check that they work correctly without your adapter as well.
RE: ANNOUNCING RECALBOX FOR THE ROCKPRO64 - ALPHA RELEASE - by Mrfixit2001 - 10-30-2018, 10:02 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 9 16,607 10-31-2025, 06:33 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 137,097 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,077 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 3,294 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 6,764 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,473 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 110,680 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 2,771 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 2,954 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 4,669 01-13-2023, 06:21 PM
Last Post: misterc
