Review/Advice for new board owner (support,purchase etc)
(12-21-2018, 02:36 PM)Bullet64 Wrote: I use an ROCKPro64 with sata adapter from pine and two 2,5'' hdd's without any problem.
rock64@rockpro64v_2_1:~$ uname -a
Linux rockpro64v_2_1 4.19.0-rc4-1071-ayufan-g10a63ec6c2a2 #1 SMP PREEMPT Mon Oct 1 07:33:40 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
But i have the same problems with an hdd at usb3. I am now using armbian and my problems are gone away. Give it a try.
Ok,
So here is what I tried that didn't work
- 4 different SATA cables
- Armbian
- Stretch-minial 7.11, bionic-minimal 7.11, 7.10
- An external computer power supply to provide power for the drive
- A new SATA PCI card
What appears to have worked is trying a different hard drive, I was using a Samsung EVO 840 SSD, now I'm using a Seagate Momentus 750GB HDD and that seems to be working.
So clearly something is causing issues with the Samsung Evo 840SSD. I'm gonna set this up with a multi-day stress test and see if it survives with the spinning disk.
RE: Review/Advice for new board owner (support,purchase etc) - by celer - 12-24-2018, 10:07 PM
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 134,223 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 1,107 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 872 08-14-2023, 07:55 AM
Last Post: kundanjha
  Cannot get my board to boot deutschlmao 11 9,701 09-05-2022, 04:23 PM
Last Post: ljones
  Support says "regulator" on the SBC burned out; how to fix? dmos 0 1,066 06-02-2022, 02:20 AM
Last Post: dmos
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 1,929 02-11-2021, 10:18 AM
Last Post: LMM
  Camera sensor support on MIPI lines abhimanyu_gr 0 1,869 01-22-2021, 09:23 AM
Last Post: abhimanyu_gr
  RockPro64 SSD Expansion Board/SATA Shield as0zial 5 8,256 10-18-2020, 08:05 PM
Last Post: revoman
  USB Type-C Display cable support (for 2 in 1: Video + Power) Paprika88 0 2,555 02-12-2020, 06:47 AM
Last Post: Paprika88
  rockpro64 support in the rockchip uboot dedoz 0 2,324 01-13-2020, 01:51 PM
Last Post: dedoz
