Sata/PCI-E problems?
I've not had a happy experience with the Pine64 supplied PCI-e card either.  Same as you, I have the NAS Case, etc, etc. In my situation, though I have just a single SSD and I get a load of dump type messages as it boots.  I have seen the blue LED on the PCI-e card just once but then couldn't access the SSD card at all.  I have tried a couple of different SSDs with no better success.  Even just the PCI-e card on its own causes problems at boot time with some odd messages, leading me to believe that I have somehow killed the card..  Using the same Linux build as yourself as well.  Also tried using the OMV build with much the same results.
I'm nearly to the point of giving a 3rd party card a try!!  In the mean time I'm using a USB3 to SATA cable to connect the SSD, which of course works just fine.  Not good though if I want to add another drive.
RockPro64 v2.1, NAS Case with SATA card
Raspberry Pi 4's doing various jobs
Jetson Nano to learn about AI
Sata/PCI-E problems? - by Takenover83 - 09-26-2018, 05:16 PM
RE: Sata/PCI-E problems? - by mocara - 09-30-2018, 12:02 AM
RE: Sata/PCI-E problems? - by Bullet64 - 09-30-2018, 04:11 AM
RE: Sata/PCI-E problems? - by jja2000 - 10-15-2018, 05:28 AM
RE: Sata/PCI-E problems? - by jja2000 - 10-20-2018, 05:36 AM
RE: Sata/PCI-E problems? - by xtract - 10-15-2018, 11:23 AM
RE: Sata/PCI-E problems? - by jja2000 - 10-15-2018, 12:12 PM
Question nand-sata-install on RAID-1 array ARMandHammer 1 2,485 02-12-2023, 03:10 AM
Last Post: igorp
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 10,792 05-20-2021, 10:04 PM
Last Post: t4_4t
  Problems with my RockPro64 tuxd3v 0 2,653 08-19-2020, 11:47 AM
Last Post: tuxd3v
  Upgrade Debian kernel on a SD/SATA drive boot combo. linuxha 6 11,835 12-12-2019, 04:43 AM
Last Post: dukla2000
  PCIe Sata II adapter and ssd TRIM bavay 0 2,640 08-16-2019, 07:49 AM
Last Post: bavay
  Problems flashing u-boot on RockPRO64 eMMC mau-tux 1 4,377 05-28-2019, 07:15 AM
Last Post: CrystalGamma
  disappearing sata drives Mentaluproar 2 4,441 05-18-2019, 09:44 PM
Last Post: Mentaluproar
  Marvell 88SE9235 PCI SATA card in LibreELEC StefanRvO 6 10,520 05-18-2019, 04:21 AM
Last Post: p1x3l3d
  Image for ZFS on PCIe SATA drives with OpenVPN and WiFi caillou 0 3,055 02-26-2019, 05:14 PM
Last Post: caillou
  PCIe Inconsistency Problems jja2000 18 27,643 12-17-2018, 01:39 PM
Last Post: jja2000
