are the usb ports on rock64 on separate bus?
Are all the USB ports on the rock64 on separate bus. I dont have a rock64, else I could check using lsusb on linux.
I need to connect camera and a sensor on two different USB ports. If they are on the same bus it results to decreased or dropped frames from the camera.
If anyone operating linux on rock64 can give me the output of lsusb command, it would be helpful.
are the usb ports on rock64 on separate bus? - by shome - 09-21-2018, 10:57 PM
  DeskPi case alternative for ROCK64 v1k699 2 11,050 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 2,713 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 2,357 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 42,154 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 9,114 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 3,371 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 18,321 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 4,451 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 6,267 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 5,580 06-08-2022, 12:44 AM
Last Post: Zoz
