Rockpro64 Sata Card kills itself
#23
So I just checked the dmesg for the new card and there are no errors.
The old/original pine64 sata card ASM1061 card had the same errors as everyone else
ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    8.597283] ata2.00: ATA-8: TOSHIBA MQ01ABD100, AX0P3D, max UDMA/100
[    8.597297] ata2.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    8.603786] ata2.00: configured for UDMA/100
[    8.604497] scsi 1:0:0:0: Direct-Access     ATA      TOSHIBA MQ01ABD1 3D   PQ: 0 ANSI: 5
[    8.605912] sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    8.605930] sd 1:0:0:0: [sda] 4096-byte physical blocks
[    8.606013] sd 1:0:0:0: [sda] Write Protect is off
[    8.606029] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    8.606168] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    8.920089] ata2.00: exception Emask 0x10 SAct 0x1 SErr 0x280100 action 0x6 frozen
[    8.920103] ata2.00: irq_stat 0x08000000, interface fatal error
[    8.920118] ata2: SError: { UnrecovData 10B8B BadCRC }
[    8.920133] ata2.00: failed command: READ FPDMA QUEUED
[    8.920159] ata2.00: cmd 60/08:00:00:00:00/00:00:00:00:00/40 tag 0 ncq dma 4096 in
                        res 40/00:00:00:00:00/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
[    8.920170] ata2.00: status: { DRDY }
[    8.920190] ata2: hard resetting link
[    9.396077] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    9.407542] ata2.00: configured for UDMA/100
[    9.407585] ata2: EH complete
[    9.540073] ata2.00: exception Emask 0x10 SAct 0x4 SErr 0x280100 action 0x6 frozen
[    9.540085] ata2.00: irq_stat 0x08000000, interface fatal error
[    9.540099] ata2: SError: { UnrecovData 10B8B BadCRC }
[    9.540112] ata2.00: failed command: READ FPDMA QUEUED
[    9.540138] ata2.00: cmd 60/08:10:08:00:00/00:00:00:00:00/40 tag 2 ncq dma 4096 in
                        res 40/00:10:08:00:00/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
[    9.540148] ata2.00: status: { DRDY }
[    9.540164] ata2: hard resetting link
[   10.016101] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   10.027560] ata2.00: configured for UDMA/100
[   10.027595] ata2: EH complete
[   10.188071] ata2.00: exception Emask 0x10 SAct 0x80 SErr 0x280100 action 0x6 frozen
[   10.188083] ata2.00: irq_stat 0x08000000, interface fatal error
[   10.188096] ata2: SError: { UnrecovData 10B8B BadCRC }
[   10.188110] ata2.00: failed command: READ FPDMA QUEUED
[   10.188136] ata2.00: cmd 60/08:38:a8:6d:70/00:00:74:00:00/40 tag 7 ncq dma 4096 in
                        res 40/00:38:a8:6d:70/00:00:74:00:00/40 Emask 0x10 (ATA bus error)
[   10.188146] ata2.00: status: { DRDY }
[   10.188162] ata2: hard resetting link
[   10.664075] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   10.675536] ata2.00: configured for UDMA/100
[   10.675570] ata2: EH complete
[   10.836071] ata2: limiting SATA link speed to 3.0 Gbps
[   10.836088] ata2.00: exception Emask 0x10 SAct 0x8000 SErr 0x280100 action 0x6 frozen
[   10.836098] ata2.00: irq_stat 0x08000000, interface fatal error
[   10.836111] ata2: SError: { UnrecovData 10B8B BadCRC }
[   10.836125] ata2.00: failed command: READ FPDMA QUEUED
[   10.836151] ata2.00: cmd 60/08:78:a0:6d:70/00:00:74:00:00/40 tag 15 ncq dma 4096 in
                        res 40/00:78:a0:6d:70/00:00:74:00:00/40 Emask 0x10 (ATA bus error)
[   10.836162] ata2.00: status: { DRDY }
[   10.836178] ata2: hard resetting link
[   11.312078] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[   11.323543] ata2.00: configured for UDMA/100
[   11.323577] ata2: EH complete
[   11.443552]  sda: sda1 sda2
[   11.446493] sd 1:0:0:0: [sda] Attached SCSI disk
[   11.447787] sda: detected capacity change from 0 to 1000204886016
[   11.448945] sda: detected capacity change from 0 to 1000204886016
SATA related dmesg for the new ASM1062 card is:
[    2.763071] ata1: SATA max UDMA/133 abar m512@0xfa010000 port 0xfa010100 irq 79
[    2.763083] ata2: SATA max UDMA/133 abar m512@0xfa010000 port 0xfa010180 irq 79
[    3.078772] ata1: SATA link down (SStatus 0 SControl 300)
[    4.092099] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.092621] ata2.15: Port Multiplier 1.2, 0x1b21:0x1092 r0, 3 ports, feat 0x5/0xf
[    4.098161] ata2.00: hard resetting link
[    4.576483] ata2.00: SATA link up 6.0 Gbps (SStatus 133 SControl 330)
[    4.576559] ata2.01: hard resetting link
[    4.892568] ata2.01: SATA link down (SStatus 0 SControl 330)
[    4.892701] ata2.02: hard resetting link
[    5.208603] ata2.02: SATA link down (SStatus 0 SControl 330)
[    5.514408] ata2.00: ATA-8: TOSHIBA MQ01ABD100, AX0P3D, max UDMA/100
[    5.514422] ata2.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    5.516231] ata2.00: configured for UDMA/100
[    5.516374] ata2: EH complete
[    5.516782] scsi 1:0:0:0: Direct-Access     ATA      TOSHIBA MQ01ABD1 3D   PQ: 0 ANSI: 5
[    5.517750] sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    5.517762] sd 1:0:0:0: [sda] 4096-byte physical blocks
[    5.517822] sd 1:0:0:0: [sda] Write Protect is off
[    5.517833] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    5.517931] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.640460]  sda: sda1 sda2
[    5.643385] sd 1:0:0:0: [sda] Attached SCSI disk
It does a couple of hard resets, but seems to work fine in the end. And I'm still stuck with excruciatingly slow network transfer speeds. I just tried to transfer a 3GB video file. It took 15 minutes at like 3 MB/s. Yes, this is over gigabit ethernet.
PS: I am running Armbian Focal minimal, kernel 5.10.y
Rockpro64 Sata Card kills itself - by jerry110 - 09-07-2018, 03:42 PM
RE: Rockpro64 Sata Card kills itself - by Luke - 01-18-2019, 05:30 AM
RE: Rockpro64 Sata Card kills itself - by nuumio - 01-18-2019, 07:16 AM
RE: Rockpro64 Sata Card kills itself - by nuumio - 01-27-2019, 01:57 AM
RE: Rockpro64 Sata Card kills itself - by aldrick - 08-21-2019, 01:52 AM
RE: Rockpro64 Sata Card kills itself - by aldrick - 12-26-2019, 04:20 AM
RE: Rockpro64 Sata Card kills itself - by aldrick - 05-08-2020, 02:00 PM
RE: Rockpro64 Sata Card kills itself - by aldrick - 05-14-2020, 06:44 AM
RE: Rockpro64 Sata Card kills itself - by AnujDatar - 05-11-2021, 02:55 PM
RE: Rockpro64 Sata Card kills itself - by LMM - 05-12-2021, 04:39 AM
RE: Rockpro64 Sata Card kills itself - by rantoie - 06-13-2021, 07:58 AM
RE: Rockpro64 Sata Card kills itself - by varac - 06-13-2021, 08:13 AM
RE: Rockpro64 Sata Card kills itself - by hyc - 06-14-2021, 12:23 PM
RE: Rockpro64 Sata Card kills itself - by rantoie - 06-15-2021, 10:11 AM
RE: Rockpro64 Sata Card kills itself - by hyc - 06-16-2021, 05:18 AM
RE: Rockpro64 Sata Card kills itself - by hyc - 06-21-2021, 05:19 AM
RE: Rockpro64 Sata Card kills itself - by fieni - 10-17-2021, 12:35 AM
RE: Rockpro64 Sata Card kills itself - by fieni - 10-20-2021, 04:36 AM
  ROCKPro64 Battery Power Supply hoarfrosty 12 1,945 04-01-2024, 10:24 PM
Last Post: nano2
  AW-CM256SM wifi card mtek 4 2,328 10-30-2023, 12:00 PM
Last Post: diederik
  Powering on the Rockpro64 JPT223 1 891 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  Which SATA card should I use my NAS server RAID5 Louysa 3 887 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 542 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 427 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 1,558 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,708 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 845 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,615 11-18-2022, 10:20 AM
Last Post: colinmarc
