Tool to Control Fan - fanctl
I updated the kernel but install still fails with the same error, maybe earlier install attempt broke something?
rock64@rockpro64:~$ find /sys -name "*pwm*" -type f
/sys/devices/platform/ff420020.pwm/pwm/pwmchip0/npwm
/sys/firmware/devicetree/base/pwm@ff420000/#pwm-cells
/sys/firmware/devicetree/base/pwm@ff420010/#pwm-cells
/sys/firmware/devicetree/base/pwm@ff420020/#pwm-cells
/sys/firmware/devicetree/base/pwm@ff420030/remote_pwm_id
/sys/firmware/devicetree/base/pwm@ff420030/#pwm-cells
/sys/firmware/devicetree/base/rockchip-suspend/rockchip,pwm-regulator-config
/sys/firmware/devicetree/base/voppwm@ff9001a0/#pwm-cells
/sys/firmware/devicetree/base/voppwm@ff8f01a0/#pwm-cells
/sys/firmware/devicetree/base/vdd-log/pwms
/sys/firmware/devicetree/base/vdd-log/rockchip,pwm_voltage
/sys/firmware/devicetree/base/vdd-log/pwm-supply
/sys/firmware/devicetree/base/vdd-log/rockchip,pwm_id
find: '/sys/kernel/debug': Permission denied
rock64@rockpro64:~$ sudo luarocks build https://raw.githubusercontent.com/tuxd3v/ats/master/ats-0.2-0.rockspec
Warning: variable CFLAGS was not passed in build_variables
gcc -c -march=armv8-a+crc -mtune=cortex-a72.cortex-a53 -fPIC -Wall -Werror -O3 -g -I/usr/include/lua5.3  -o debug.o src/debug.c
gcc -c -march=armv8-a+crc -mtune=cortex-a72.cortex-a53 -fPIC -Wall -Werror -O3 -g -I/usr/include/lua5.3  -o ats.o src/ats.c
gcc -shared -Wl,-soname,ats.so.0 -llua5.3  -o ats.so.0.9 debug.o ats.o
Install ATS Tool ..................: ats in /usr/local/sbin
Install ATS Config ................: ats.config in /etc
Install ATS Service File ..........: ats.service in systemd
Remove previous ATS Library .......: ats.so.* from /usr/local/lib/lua/5.3
Install new ATS Library ...........: ats.so.0.9 in /usr/local/lib/lua/5.3
Create soname symLink .............: ats.so in /usr/local/lib/lua/5.3
Failed to enable unit: Unit file ats.service does not exist.
Makefile:103: recipe for target 'install' failed
make: *** [install] Error 1
Error: Build error: Failed installing.
rock64@rockpro64:~$ uname -a
Linux rockpro64 4.4.138-1097-rockchip-ayufan-gb5128c0a1684 #1 SMP Sat Sep 29 15:08:06 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
rock64@rockpro64:~$
Tool to Control Fan - fanctl - by tuxd3v - 09-01-2018, 07:52 PM
RE: Tool to Control Fan - fanctl - by tllim - 09-02-2018, 11:56 PM
RE: Tool to Control Fan - fanctl - by whitehat - 09-03-2018, 12:34 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-04-2018, 08:15 AM
RE: Tool to Control Fan - fanctl - by whitehat - 09-04-2018, 06:14 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-04-2018, 07:28 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-04-2018, 06:29 AM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-07-2018, 03:45 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-08-2018, 09:10 AM
RE: Tool to Control Fan - fanctl - by rookieone - 09-07-2018, 10:53 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-08-2018, 04:36 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-08-2018, 10:45 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-13-2018, 02:45 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-13-2018, 06:57 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-14-2018, 05:26 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-15-2018, 04:03 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-15-2018, 02:13 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-15-2018, 04:05 PM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-21-2018, 01:54 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-21-2018, 09:26 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-20-2018, 11:26 AM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-19-2018, 10:42 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-19-2018, 04:44 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-19-2018, 09:27 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-21-2018, 09:43 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-21-2018, 01:54 PM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-22-2018, 03:27 AM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-22-2018, 03:44 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-22-2018, 05:02 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-22-2018, 10:56 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-03-2018, 06:23 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-09-2018, 11:45 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 10-10-2018, 03:13 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-11-2018, 06:34 PM
RE: Tool to Control Fan - fanctl - by dkebler - 10-14-2018, 11:36 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-15-2018, 05:38 AM
RE: Tool to Control Fan - fanctl - by dkebler - 10-15-2018, 03:37 PM
RE: Tool to Control Fan - fanctl - by y0sh - 10-18-2018, 01:27 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-18-2018, 03:43 PM
RE: Tool to Control Fan - fanctl - by y0sh - 10-19-2018, 04:34 PM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-21-2018, 02:06 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-21-2018, 07:39 PM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 12:53 AM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 01:18 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-22-2018, 06:08 AM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 08:32 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-22-2018, 10:23 AM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 03:29 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-22-2018, 04:07 PM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 09:10 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-22-2018, 11:12 PM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-23-2018, 12:38 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-23-2018, 12:26 PM
RE: Tool to Control Fan - fanctl - by Girbur - 11-10-2018, 02:46 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-10-2018, 08:44 PM
RE: Tool to Control Fan - fanctl - by Girbur - 11-10-2018, 11:39 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-11-2018, 10:26 AM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-10-2018, 03:32 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-10-2018, 09:37 AM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-11-2018, 02:02 AM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-11-2018, 02:10 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-11-2018, 11:28 AM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-12-2018, 01:57 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-12-2018, 07:33 PM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-13-2018, 09:47 AM
RE: Tool to Control Fan - fanctl - by Girbur - 11-13-2018, 11:30 AM
RE: Tool to Control Fan - fanctl - by stFfn - 11-13-2018, 03:26 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-13-2018, 10:39 PM
RE: Tool to Control Fan - fanctl - by Girbur - 11-14-2018, 05:46 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-14-2018, 10:41 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 11-13-2018, 05:42 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-14-2018, 11:20 AM
RE: Tool to Control Fan - fanctl - by stFfn - 11-14-2018, 12:50 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-14-2018, 06:24 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-15-2018, 04:41 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-15-2018, 08:42 AM
RE: Tool to Control Fan - fanctl - by Girbur - 11-17-2018, 11:52 PM
RE: Tool to Control Fan - fanctl - by Raikiri1316 - 11-14-2018, 09:51 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-15-2018, 10:19 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-15-2018, 11:39 AM
RE: Tool to Control Fan - fanctl - by stFfn - 11-15-2018, 01:39 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-15-2018, 03:38 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-15-2018, 05:02 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-18-2018, 10:36 AM
RE: Tool to Control Fan - fanctl - by Girbur - 11-18-2018, 01:14 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-18-2018, 01:57 PM
RE: Tool to Control Fan - fanctl - by Girbur - 11-18-2018, 01:59 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-19-2018, 03:28 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-21-2018, 01:32 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-21-2018, 05:18 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-21-2018, 05:28 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-21-2018, 07:03 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-17-2018, 07:44 AM
RE: Tool to Control Fan - fanctl - by Drago - 11-20-2018, 11:17 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-20-2018, 03:26 PM
RE: Tool to Control Fan - fanctl - by Drago - 11-20-2018, 03:31 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-20-2018, 06:42 PM
RE: Tool to Control Fan - fanctl - by Drago - 11-20-2018, 08:00 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-20-2018, 09:10 PM
RE: Tool to Control Fan - fanctl - by Drago - 11-20-2018, 09:19 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-21-2018, 10:39 AM
RE: Tool to Control Fan - fanctl - by Drago - 11-21-2018, 10:43 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-22-2018, 08:20 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-06-2018, 08:16 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-12-2018, 09:27 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-21-2018, 06:16 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-22-2018, 06:36 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-22-2018, 01:58 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-22-2018, 03:52 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-23-2018, 08:37 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 07:45 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-25-2018, 11:10 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 01:00 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-25-2018, 01:52 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 02:09 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-25-2018, 02:26 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 05:38 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-25-2018, 05:59 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 09:29 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-26-2018, 03:33 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-26-2018, 05:46 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-26-2018, 05:56 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 01-03-2019, 06:26 AM
RE: Tool to Control Fan - fanctl - by stFfn - 01-03-2019, 11:50 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-28-2018, 03:09 PM
RE: Tool to Control Fan - fanctl - by stFfn - 01-05-2019, 01:05 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 01-05-2019, 07:50 PM
RE: Tool to Control Fan - fanctl - by Luke - 04-05-2019, 09:24 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-05-2019, 11:35 AM
RE: Tool to Control Fan - fanctl - by Luke - 04-05-2019, 01:05 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-05-2019, 04:29 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-06-2019, 08:42 AM
RE: Tool to Control Fan - fanctl - by Luke - 04-07-2019, 03:03 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-22-2019, 12:16 PM
RE: Tool to Control Fan - fanctl - by Farley56 - 04-30-2019, 10:33 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-30-2019, 11:38 AM
RE: Tool to Control Fan - fanctl - by Farley56 - 04-30-2019, 08:42 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-01-2019, 12:48 AM
RE: Tool to Control Fan - fanctl - by Farley56 - 05-01-2019, 01:17 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-01-2019, 01:50 PM
RE: Tool to Control Fan - fanctl - by Farley56 - 05-01-2019, 07:18 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-01-2019, 08:54 PM
RE: Tool to Control Fan - fanctl - by Farley56 - 05-02-2019, 07:44 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-03-2019, 10:26 AM
RE: Tool to Control Fan - fanctl - by Farley56 - 05-06-2019, 02:18 PM
RE: Tool to Control Fan - fanctl - by Luke - 05-08-2019, 02:56 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-17-2019, 05:34 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-18-2019, 03:57 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-18-2019, 09:26 PM
RE: Tool to Control Fan - fanctl - by tikonen - 05-20-2019, 05:07 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-20-2019, 09:11 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-20-2019, 03:47 PM
RE: Tool to Control Fan - fanctl - by tikonen - 05-22-2019, 12:44 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-23-2019, 02:00 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-24-2019, 09:17 AM
RE: Tool to Control Fan - fanctl - by tikonen - 05-27-2019, 05:24 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-30-2019, 02:22 PM
RE: Tool to Control Fan - fanctl - by tikonen - 06-03-2019, 04:12 AM
RE: Tool to Control Fan - fanctl - by tikonen - 06-06-2019, 01:10 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 06-30-2019, 11:07 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 06-30-2019, 05:27 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 07-01-2019, 08:47 AM
RE: Tool to Control Fan - fanctl - by kromsam - 07-01-2019, 08:28 AM
RE: Tool to Control Fan - fanctl - by kromsam - 07-03-2019, 09:43 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 07-02-2019, 06:24 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 07-02-2019, 06:14 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 07-08-2019, 08:21 PM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-01-2019, 08:13 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-01-2019, 09:02 AM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-01-2019, 04:09 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-01-2019, 05:57 PM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-01-2019, 06:37 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-02-2019, 03:44 AM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-02-2019, 06:49 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-02-2019, 08:52 AM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-02-2019, 09:16 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-02-2019, 09:51 AM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-02-2019, 02:09 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-02-2019, 04:34 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-05-2019, 08:04 AM
RE: Tool to Control Fan - fanctl - by Neo2018 - 02-24-2021, 01:42 PM
RE: Tool to Control Fan - fanctl - by Neo2018 - 04-05-2021, 02:02 AM
RE: Tool to Control Fan - fanctl - by kuleszdl - 03-07-2021, 07:19 AM
RE: Tool to Control Fan - fanctl - by Neo2018 - 03-14-2021, 01:56 AM
RE: Tool to Control Fan - fanctl - by kuleszdl - 03-14-2021, 05:38 PM
RE: Tool to Control Fan - fanctl - by Neo2018 - 03-15-2021, 03:21 AM
  PWM Fan Control Python Script superbox 0 1,341 02-04-2022, 10:02 PM
Last Post: superbox
