Tool to Control Fan - fanctl
#72
(11-14-2018, 11:20 AM)tuxd3v Wrote:
(11-13-2018, 03:26 PM)stFfn Wrote: Hello,
i´ve just gotten my RockPro64 + the Nascase... and i´ve also notived that the fan does not spin up....
im a linux noob and somehow im not able to install your fan controll programm... im connected to the RockPro64 with SSH as Root. and when i try to install ist, i geht these  error messages...
root@rockpro64Nas:~# luarocks build https://raw.githubusercontent.com/tuxd3v/ats/master/ats-master-0.rockspec
Cloning into 'ats'...
remote: Enumerating objects: 16, done.
remote: Counting objects: 100% (16/16), done.
remote: Compressing objects: 100% (15/15), done.
remote: Total 16 (delta 1), reused 6 (delta 0), pack-reused 0
Receiving objects: 100% (16/16), 95.96 KiB | 0 bytes/s, done.
Resolving deltas: 100% (1/1), done.
Warning: variable CFLAGS was not passed in build_variables
gcc -c -march=armv8-a+crc -mtune=cortex-a72.cortex-a53 -fPIC -Wall -Werror -O3 -g -I/usr/include/lua5.3  -o src/ats.o src/ats.c
gcc -shared -Wl,-soname,ats.so.0 -llua5.3  -o ats.so.0.2 src/ats.o
Install ATS Tool ..................: ats in /usr/local/sbin
Install ATS Service File ..........: ats.service in systemd
Remove previous ATS Library .......: ats.so.* from /usr/local/lib/lua/5.3
Install new ATS Library ...........: ats.so.0.2 in /usr/local/lib/lua/5.3
Create soname symLink .............: ats.so in /usr/local/lib/lua/5.3
Starting ATS Service..
● ats.service - ATS - Active Thermal Service
  Loaded: loaded (/lib/systemd/system/ats.service; enabled; vendor preset: enabled)
  Active: activating (auto-restart) (Result: exit-code) since Tue 2018-11-13 21:18:25 UTC; 978ms a
go
 Process: 14532 ExecStart=/usr/local/sbin/ats (code=exited, status=127)
Main PID: 14532 (code=exited, status=127)
Nov 13 21:18:25 rockpro64Nas systemd[1]: ats.service: Unit entered failed state.
Nov 13 21:18:25 rockpro64Nas systemd[1]: ats.service: Failed with result 'exit-code'.
Makefile:46: recipe for target 'install' failed
make: *** [install] Error 3
Error: Build error: Failed installing.
Could you please help me out? the HDD´s getting to 60°C during my Raid Setup.... i want to avoid HDD damage...
Greetings
Steffen
Can you post the result of this command?
A exit code of 127, should be a shell exit code, maybe it won't find the binary or so..
ats --test
also you could change the profile, be default it his on profile 1, which is for smaller fans,
you could change for profile2, or profile3,
But first it would be nice to have the output of that command.
Hey this is what happenes....
root@rockpro64Nas:~# ats --test
/usr/bin/env: 'lua': No such file or directory
Tool to Control Fan - fanctl - by tuxd3v - 09-01-2018, 07:52 PM
RE: Tool to Control Fan - fanctl - by tllim - 09-02-2018, 11:56 PM
RE: Tool to Control Fan - fanctl - by whitehat - 09-03-2018, 12:34 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-04-2018, 08:15 AM
RE: Tool to Control Fan - fanctl - by whitehat - 09-04-2018, 06:14 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-04-2018, 07:28 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-04-2018, 06:29 AM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-07-2018, 03:45 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-08-2018, 09:10 AM
RE: Tool to Control Fan - fanctl - by rookieone - 09-07-2018, 10:53 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-08-2018, 04:36 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-08-2018, 10:45 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-13-2018, 02:45 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-13-2018, 06:57 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-14-2018, 05:26 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-15-2018, 04:03 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-15-2018, 02:13 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-15-2018, 04:05 PM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-21-2018, 01:54 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-21-2018, 09:26 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-20-2018, 11:26 AM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-19-2018, 10:42 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-19-2018, 04:44 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-19-2018, 09:27 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-21-2018, 09:43 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-21-2018, 01:54 PM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-22-2018, 03:27 AM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-22-2018, 03:44 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-22-2018, 05:02 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-22-2018, 10:56 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-03-2018, 06:23 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-09-2018, 11:45 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 10-10-2018, 03:13 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-11-2018, 06:34 PM
RE: Tool to Control Fan - fanctl - by dkebler - 10-14-2018, 11:36 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-15-2018, 05:38 AM
RE: Tool to Control Fan - fanctl - by dkebler - 10-15-2018, 03:37 PM
RE: Tool to Control Fan - fanctl - by y0sh - 10-18-2018, 01:27 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-18-2018, 03:43 PM
RE: Tool to Control Fan - fanctl - by y0sh - 10-19-2018, 04:34 PM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-21-2018, 02:06 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-21-2018, 07:39 PM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 12:53 AM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 01:18 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-22-2018, 06:08 AM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 08:32 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-22-2018, 10:23 AM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 03:29 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-22-2018, 04:07 PM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 09:10 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-22-2018, 11:12 PM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-23-2018, 12:38 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-23-2018, 12:26 PM
RE: Tool to Control Fan - fanctl - by Girbur - 11-10-2018, 02:46 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-10-2018, 08:44 PM
RE: Tool to Control Fan - fanctl - by Girbur - 11-10-2018, 11:39 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-11-2018, 10:26 AM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-10-2018, 03:32 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-10-2018, 09:37 AM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-11-2018, 02:02 AM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-11-2018, 02:10 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-11-2018, 11:28 AM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-12-2018, 01:57 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-12-2018, 07:33 PM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-13-2018, 09:47 AM
RE: Tool to Control Fan - fanctl - by Girbur - 11-13-2018, 11:30 AM
RE: Tool to Control Fan - fanctl - by stFfn - 11-13-2018, 03:26 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-13-2018, 10:39 PM
RE: Tool to Control Fan - fanctl - by Girbur - 11-14-2018, 05:46 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-14-2018, 10:41 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 11-13-2018, 05:42 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-14-2018, 11:20 AM
RE: Tool to Control Fan - fanctl - by stFfn - 11-14-2018, 12:50 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-14-2018, 06:24 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-15-2018, 04:41 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-15-2018, 08:42 AM
RE: Tool to Control Fan - fanctl - by Girbur - 11-17-2018, 11:52 PM
RE: Tool to Control Fan - fanctl - by Raikiri1316 - 11-14-2018, 09:51 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-15-2018, 10:19 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-15-2018, 11:39 AM
RE: Tool to Control Fan - fanctl - by stFfn - 11-15-2018, 01:39 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-15-2018, 03:38 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-15-2018, 05:02 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-18-2018, 10:36 AM
RE: Tool to Control Fan - fanctl - by Girbur - 11-18-2018, 01:14 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-18-2018, 01:57 PM
RE: Tool to Control Fan - fanctl - by Girbur - 11-18-2018, 01:59 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-19-2018, 03:28 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-21-2018, 01:32 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-21-2018, 05:18 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-21-2018, 05:28 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-21-2018, 07:03 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-17-2018, 07:44 AM
RE: Tool to Control Fan - fanctl - by Drago - 11-20-2018, 11:17 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-20-2018, 03:26 PM
RE: Tool to Control Fan - fanctl - by Drago - 11-20-2018, 03:31 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-20-2018, 06:42 PM
RE: Tool to Control Fan - fanctl - by Drago - 11-20-2018, 08:00 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-20-2018, 09:10 PM
RE: Tool to Control Fan - fanctl - by Drago - 11-20-2018, 09:19 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-21-2018, 10:39 AM
RE: Tool to Control Fan - fanctl - by Drago - 11-21-2018, 10:43 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-22-2018, 08:20 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-06-2018, 08:16 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-12-2018, 09:27 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-21-2018, 06:16 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-22-2018, 06:36 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-22-2018, 01:58 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-22-2018, 03:52 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-23-2018, 08:37 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 07:45 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-25-2018, 11:10 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 01:00 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-25-2018, 01:52 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 02:09 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-25-2018, 02:26 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 05:38 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-25-2018, 05:59 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 09:29 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-26-2018, 03:33 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-26-2018, 05:46 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-26-2018, 05:56 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 01-03-2019, 06:26 AM
RE: Tool to Control Fan - fanctl - by stFfn - 01-03-2019, 11:50 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-28-2018, 03:09 PM
RE: Tool to Control Fan - fanctl - by stFfn - 01-05-2019, 01:05 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 01-05-2019, 07:50 PM
RE: Tool to Control Fan - fanctl - by Luke - 04-05-2019, 09:24 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-05-2019, 11:35 AM
RE: Tool to Control Fan - fanctl - by Luke - 04-05-2019, 01:05 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-05-2019, 04:29 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-06-2019, 08:42 AM
RE: Tool to Control Fan - fanctl - by Luke - 04-07-2019, 03:03 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-22-2019, 12:16 PM
RE: Tool to Control Fan - fanctl - by Farley56 - 04-30-2019, 10:33 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-30-2019, 11:38 AM
RE: Tool to Control Fan - fanctl - by Farley56 - 04-30-2019, 08:42 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-01-2019, 12:48 AM
RE: Tool to Control Fan - fanctl - by Farley56 - 05-01-2019, 01:17 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-01-2019, 01:50 PM
RE: Tool to Control Fan - fanctl - by Farley56 - 05-01-2019, 07:18 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-01-2019, 08:54 PM
RE: Tool to Control Fan - fanctl - by Farley56 - 05-02-2019, 07:44 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-03-2019, 10:26 AM
RE: Tool to Control Fan - fanctl - by Farley56 - 05-06-2019, 02:18 PM
RE: Tool to Control Fan - fanctl - by Luke - 05-08-2019, 02:56 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-17-2019, 05:34 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-18-2019, 03:57 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-18-2019, 09:26 PM
RE: Tool to Control Fan - fanctl - by tikonen - 05-20-2019, 05:07 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-20-2019, 09:11 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-20-2019, 03:47 PM
RE: Tool to Control Fan - fanctl - by tikonen - 05-22-2019, 12:44 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-23-2019, 02:00 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-24-2019, 09:17 AM
RE: Tool to Control Fan - fanctl - by tikonen - 05-27-2019, 05:24 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-30-2019, 02:22 PM
RE: Tool to Control Fan - fanctl - by tikonen - 06-03-2019, 04:12 AM
RE: Tool to Control Fan - fanctl - by tikonen - 06-06-2019, 01:10 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 06-30-2019, 11:07 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 06-30-2019, 05:27 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 07-01-2019, 08:47 AM
RE: Tool to Control Fan - fanctl - by kromsam - 07-01-2019, 08:28 AM
RE: Tool to Control Fan - fanctl - by kromsam - 07-03-2019, 09:43 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 07-02-2019, 06:24 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 07-02-2019, 06:14 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 07-08-2019, 08:21 PM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-01-2019, 08:13 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-01-2019, 09:02 AM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-01-2019, 04:09 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-01-2019, 05:57 PM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-01-2019, 06:37 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-02-2019, 03:44 AM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-02-2019, 06:49 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-02-2019, 08:52 AM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-02-2019, 09:16 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-02-2019, 09:51 AM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-02-2019, 02:09 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-02-2019, 04:34 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-05-2019, 08:04 AM
RE: Tool to Control Fan - fanctl - by Neo2018 - 02-24-2021, 01:42 PM
RE: Tool to Control Fan - fanctl - by Neo2018 - 04-05-2021, 02:02 AM
RE: Tool to Control Fan - fanctl - by kuleszdl - 03-07-2021, 07:19 AM
RE: Tool to Control Fan - fanctl - by Neo2018 - 03-14-2021, 01:56 AM
RE: Tool to Control Fan - fanctl - by kuleszdl - 03-14-2021, 05:38 PM
RE: Tool to Control Fan - fanctl - by Neo2018 - 03-15-2021, 03:21 AM
  PWM Fan Control Python Script superbox 0 2,379 02-04-2022, 10:02 PM
Last Post: superbox
