Tool to Control Fan - fanctl
#60
(11-10-2018, 09:37 AM)tuxd3v Wrote:
(11-10-2018, 03:32 AM)dreadbv Wrote: Hello, can you help me with this error?
Cloning into 'ats'...
remote: Enumerating objects: 16, done.
remote: Counting objects: 100% (16/16), done.
remote: Compressing objects: 100% (15/15), done.
remote: Total 16 (delta 1), reused 5 (delta 0), pack-reused 0
Receiving objects: 100% (16/16), 95.89 KiB | 0 bytes/s, done.
Resolving deltas: 100% (1/1), done.
Warning: variable CFLAGS was not passed in build_variables
gcc -c -march=armv8-a+simd+crypto+crc -mtune=cortex-a72.cortex-a53 -fPIC -Wall -Werror -O3 -g -I/usr/include/lua5.3  -o src/ats.o src/ats.c
gcc: error: unrecognized argument in option '-march=armv8-a+simd+crypto+crc'
gcc: note: valid arguments to '-march=' are: armv2 armv2a armv3 armv3m armv4 armv4t armv5 armv5e armv5t armv5te armv6 armv6-m armv6j armv6k armv6kz armv6s-m armv6t2 armv6z armv6zk armv7 armv7-a armv7-m armv7-r armv7e-m armv7ve armv8-a armv8-a+crc armv8.1-a armv8.1-a+crc iwmmxt iwmmxt2 native
Makefile:36: recipe for target 'src/ats.o' failed
make: *** [src/ats.o] Error 1
Error: Build error: Failed building.
Hello ,
Can you post the result if this command?
gcc -v
This should be related to a older version of gcc.
In Fact for now I could drop some flags, so that you would be able to compile.
It would be nice to know, your gcc version with the command above.
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/6/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: ../src/configure -v --with-pkgversion='Debian 6.3.0-18+deb9u1' --with-bugurl=file:///usr/share/doc/gcc-6/README.Bugs --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-6 --program-prefix=arm-linux-gnueabihf- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libitm --disable-libquadmath --enable-plugin --enable-default-pie --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-6-armhf/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-6-armhf --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-6-armhf --with-arch-directory=arm --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --with-target-system-zlib --enable-objc-gc=auto --enable-multiarch --disable-sjlj-exceptions --with-arch=armv7-a --with-fpu=vfpv3-d16 --with-float=hard --with-mode=thumb --enable-checking=release --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
Thread model: posix
gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1)
Tool to Control Fan - fanctl - by tuxd3v - 09-01-2018, 07:52 PM
RE: Tool to Control Fan - fanctl - by tllim - 09-02-2018, 11:56 PM
RE: Tool to Control Fan - fanctl - by whitehat - 09-03-2018, 12:34 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-04-2018, 08:15 AM
RE: Tool to Control Fan - fanctl - by whitehat - 09-04-2018, 06:14 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-04-2018, 07:28 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-04-2018, 06:29 AM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-07-2018, 03:45 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-08-2018, 09:10 AM
RE: Tool to Control Fan - fanctl - by rookieone - 09-07-2018, 10:53 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-08-2018, 04:36 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-08-2018, 10:45 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-13-2018, 02:45 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-13-2018, 06:57 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-14-2018, 05:26 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-15-2018, 04:03 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-15-2018, 02:13 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-15-2018, 04:05 PM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-21-2018, 01:54 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-21-2018, 09:26 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-20-2018, 11:26 AM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-19-2018, 10:42 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-19-2018, 04:44 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-19-2018, 09:27 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-21-2018, 09:43 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 09-21-2018, 01:54 PM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-22-2018, 03:27 AM
RE: Tool to Control Fan - fanctl - by romtorwator - 09-22-2018, 03:44 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-22-2018, 05:02 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 09-22-2018, 10:56 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-03-2018, 06:23 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-09-2018, 11:45 AM
RE: Tool to Control Fan - fanctl - by amator_1 - 10-10-2018, 03:13 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-11-2018, 06:34 PM
RE: Tool to Control Fan - fanctl - by dkebler - 10-14-2018, 11:36 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-15-2018, 05:38 AM
RE: Tool to Control Fan - fanctl - by dkebler - 10-15-2018, 03:37 PM
RE: Tool to Control Fan - fanctl - by y0sh - 10-18-2018, 01:27 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-18-2018, 03:43 PM
RE: Tool to Control Fan - fanctl - by y0sh - 10-19-2018, 04:34 PM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-21-2018, 02:06 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-21-2018, 07:39 PM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 12:53 AM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 01:18 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-22-2018, 06:08 AM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 08:32 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-22-2018, 10:23 AM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 03:29 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-22-2018, 04:07 PM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-22-2018, 09:10 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-22-2018, 11:12 PM
RE: Tool to Control Fan - fanctl - by O1Hitman1O - 10-23-2018, 12:38 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-23-2018, 12:26 PM
RE: Tool to Control Fan - fanctl - by Girbur - 11-10-2018, 02:46 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-10-2018, 08:44 PM
RE: Tool to Control Fan - fanctl - by Girbur - 11-10-2018, 11:39 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-11-2018, 10:26 AM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-10-2018, 03:32 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-10-2018, 09:37 AM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-11-2018, 02:02 AM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-11-2018, 02:10 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-11-2018, 11:28 AM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-12-2018, 01:57 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-12-2018, 07:33 PM
RE: Tool to Control Fan - fanctl - by dreadbv - 11-13-2018, 09:47 AM
RE: Tool to Control Fan - fanctl - by Girbur - 11-13-2018, 11:30 AM
RE: Tool to Control Fan - fanctl - by stFfn - 11-13-2018, 03:26 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-13-2018, 10:39 PM
RE: Tool to Control Fan - fanctl - by Girbur - 11-14-2018, 05:46 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-14-2018, 10:41 PM
RE: Tool to Control Fan - fanctl - by romtorwator - 11-13-2018, 05:42 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-14-2018, 11:20 AM
RE: Tool to Control Fan - fanctl - by stFfn - 11-14-2018, 12:50 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-14-2018, 06:24 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-15-2018, 04:41 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-15-2018, 08:42 AM
RE: Tool to Control Fan - fanctl - by Girbur - 11-17-2018, 11:52 PM
RE: Tool to Control Fan - fanctl - by Raikiri1316 - 11-14-2018, 09:51 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-15-2018, 10:19 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-15-2018, 11:39 AM
RE: Tool to Control Fan - fanctl - by stFfn - 11-15-2018, 01:39 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-15-2018, 03:38 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-15-2018, 05:02 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-18-2018, 10:36 AM
RE: Tool to Control Fan - fanctl - by Girbur - 11-18-2018, 01:14 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-18-2018, 01:57 PM
RE: Tool to Control Fan - fanctl - by Girbur - 11-18-2018, 01:59 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-19-2018, 03:28 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-21-2018, 01:32 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-21-2018, 05:18 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-21-2018, 05:28 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-21-2018, 07:03 PM
RE: Tool to Control Fan - fanctl - by stFfn - 11-17-2018, 07:44 AM
RE: Tool to Control Fan - fanctl - by Drago - 11-20-2018, 11:17 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-20-2018, 03:26 PM
RE: Tool to Control Fan - fanctl - by Drago - 11-20-2018, 03:31 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-20-2018, 06:42 PM
RE: Tool to Control Fan - fanctl - by Drago - 11-20-2018, 08:00 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-20-2018, 09:10 PM
RE: Tool to Control Fan - fanctl - by Drago - 11-20-2018, 09:19 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-21-2018, 10:39 AM
RE: Tool to Control Fan - fanctl - by Drago - 11-21-2018, 10:43 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 11-22-2018, 08:20 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-06-2018, 08:16 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-12-2018, 09:27 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-21-2018, 06:16 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-22-2018, 06:36 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-22-2018, 01:58 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-22-2018, 03:52 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-23-2018, 08:37 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 07:45 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-25-2018, 11:10 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 01:00 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-25-2018, 01:52 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 02:09 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-25-2018, 02:26 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 05:38 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-25-2018, 05:59 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-25-2018, 09:29 PM
RE: Tool to Control Fan - fanctl - by stFfn - 12-26-2018, 03:33 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 12-26-2018, 05:46 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-26-2018, 05:56 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 01-03-2019, 06:26 AM
RE: Tool to Control Fan - fanctl - by stFfn - 01-03-2019, 11:50 AM
RE: Tool to Control Fan - fanctl - by stFfn - 12-28-2018, 03:09 PM
RE: Tool to Control Fan - fanctl - by stFfn - 01-05-2019, 01:05 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 01-05-2019, 07:50 PM
RE: Tool to Control Fan - fanctl - by Luke - 04-05-2019, 09:24 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-05-2019, 11:35 AM
RE: Tool to Control Fan - fanctl - by Luke - 04-05-2019, 01:05 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-05-2019, 04:29 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-06-2019, 08:42 AM
RE: Tool to Control Fan - fanctl - by Luke - 04-07-2019, 03:03 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-22-2019, 12:16 PM
RE: Tool to Control Fan - fanctl - by Farley56 - 04-30-2019, 10:33 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 04-30-2019, 11:38 AM
RE: Tool to Control Fan - fanctl - by Farley56 - 04-30-2019, 08:42 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-01-2019, 12:48 AM
RE: Tool to Control Fan - fanctl - by Farley56 - 05-01-2019, 01:17 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-01-2019, 01:50 PM
RE: Tool to Control Fan - fanctl - by Farley56 - 05-01-2019, 07:18 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-01-2019, 08:54 PM
RE: Tool to Control Fan - fanctl - by Farley56 - 05-02-2019, 07:44 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-03-2019, 10:26 AM
RE: Tool to Control Fan - fanctl - by Farley56 - 05-06-2019, 02:18 PM
RE: Tool to Control Fan - fanctl - by Luke - 05-08-2019, 02:56 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-17-2019, 05:34 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-18-2019, 03:57 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-18-2019, 09:26 PM
RE: Tool to Control Fan - fanctl - by tikonen - 05-20-2019, 05:07 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-20-2019, 09:11 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-20-2019, 03:47 PM
RE: Tool to Control Fan - fanctl - by tikonen - 05-22-2019, 12:44 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-23-2019, 02:00 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-24-2019, 09:17 AM
RE: Tool to Control Fan - fanctl - by tikonen - 05-27-2019, 05:24 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 05-30-2019, 02:22 PM
RE: Tool to Control Fan - fanctl - by tikonen - 06-03-2019, 04:12 AM
RE: Tool to Control Fan - fanctl - by tikonen - 06-06-2019, 01:10 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 06-30-2019, 11:07 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 06-30-2019, 05:27 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 07-01-2019, 08:47 AM
RE: Tool to Control Fan - fanctl - by kromsam - 07-01-2019, 08:28 AM
RE: Tool to Control Fan - fanctl - by kromsam - 07-03-2019, 09:43 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 07-02-2019, 06:24 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 07-02-2019, 06:14 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 07-08-2019, 08:21 PM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-01-2019, 08:13 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-01-2019, 09:02 AM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-01-2019, 04:09 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-01-2019, 05:57 PM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-01-2019, 06:37 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-02-2019, 03:44 AM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-02-2019, 06:49 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-02-2019, 08:52 AM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-02-2019, 09:16 AM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-02-2019, 09:51 AM
RE: Tool to Control Fan - fanctl - by g_t_j - 08-02-2019, 02:09 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 08-02-2019, 04:34 PM
RE: Tool to Control Fan - fanctl - by tuxd3v - 10-05-2019, 08:04 AM
RE: Tool to Control Fan - fanctl - by Neo2018 - 02-24-2021, 01:42 PM
RE: Tool to Control Fan - fanctl - by Neo2018 - 04-05-2021, 02:02 AM
RE: Tool to Control Fan - fanctl - by kuleszdl - 03-07-2021, 07:19 AM
RE: Tool to Control Fan - fanctl - by Neo2018 - 03-14-2021, 01:56 AM
RE: Tool to Control Fan - fanctl - by kuleszdl - 03-14-2021, 05:38 PM
RE: Tool to Control Fan - fanctl - by Neo2018 - 03-15-2021, 03:21 AM
  PWM Fan Control Python Script superbox 0 2,379 02-04-2022, 10:02 PM
Last Post: superbox
