KDE Neon Pinebook remix edition RC image
(08-23-2018, 08:16 AM)mklvr Wrote: I haven't slept for about 24 hours, so that may be the root cause for this, but why are several news sources:
https://news.softpedia.com/news/kde-neon...2368.shtml
https://www.omgubuntu.co.uk/2018/08/kde-...untu%21%29
https://dot.kde.org/2018/08/22/kde-plasm...p-pinebook
directing me here for "detailed installation instructions". I'm not seeing anything of the sort. I suspect you need to 'dd' the image to an sdcard, but that's not hinted at here.
Am I missing something? Am I too early? What's going on?
P.S. Kudos to the KDE devs.
Not sure what the outlets mean by 'detailed instructions' either. Instructions on how to flash the internal eMMC on the Pinebook can be found here.
But since many sources point online here, I feel compelled to quickly write up the missing kind-of detailed instructions:
In short, you can flash the eMMC on the Pinebook either via: 1) FEL (outline in link above); 2) booting from SD and flashing to eMMC (some OS images have their own installers while on other OS' you have dd the eMMC manually); 3) using a special SD card image (such as this one).
As for 3), its worth mentioning that it can be easily modified to flash any OS image to eMMC by i) flashing the image above to a SD card ii) mounting the rootfs partition of the SD card on your computer (I am assuming you're on *nix) iii) deleting 'pinebook.img' from the partition iv) copying over whatever OS image you want on your Pinebook's eMMC v) renaming the OS image you copied over 'pinebook.img' vi) and lastly putting it into your Pinebook, powering it on and following onscreen instructions (NB disregard that it says 'flashing Ubuntu Mate' -> its actually flashing whatever OS image you placed in the SD rootfs).
I trust this helps.
RE: KDE Neon Pinebook remix edition RC image - by Luke - 08-23-2018, 02:29 PM
Possibly Related Threads...
  Pinebook Wlan Driver does not work properly matze79 2 60 2 hours ago
Last Post: matze79
  Pinebook is going the way of Betamax? trigger 4 215 12-09-2019, 12:40 PM
Last Post: matze79
  Q4OS for PINEBOOK q4osteam 89 27,371 11-12-2019, 09:17 PM
Last Post: ac8dg
Information Manjaro ARM for Pinebook erchache2000 68 5,619 11-08-2019, 07:36 AM
Last Post: fitter
  Pinebook 1080p / KDE Neon freezes every 5-10 min pyrrhumain 12 634 11-02-2019, 10:03 AM
Last Post: rookieone
  Are Pinebook images compatible with Pine64+? starcrescent 7 186 09-18-2019, 09:22 AM
  Archlinux (mainline) for Pinebook anarsoul 51 15,029 08-28-2019, 05:23 PM
Last Post: conlaoch
  KDE Neon Image - Where can i find the Kernel Source ? matze79 4 190 08-14-2019, 04:27 AM
Last Post: matze79
  will openMP work on a pinebook? rustythorn 2 140 07-23-2019, 01:42 PM
  Armbian - Xenial Desktop (Pinebook) pineadmin 83 18,904 07-17-2019, 01:22 PM
Last Post: catsmile
