Hardware issue overheating while booting and fail to boot
(08-21-2018, 11:10 AM)DIDquest Wrote: The link in the Wiki regarding the recover button led to a great little tutorial on using a serial connection to access the board… which I will try once I find that serial console… Unfortunately, it contained no reference to what the recovery button does or extra steps that you will have to do. I have been curious about what that button will do, but without an official explanation (in a manual or something), I have been hesitant to press it. I hope it just resets the default hardware values (like a factory reset), has anyone used it before to verify this?
Ooops Blush
Corrected the wiki - try this now.
It should connect you via OTG to something low level on your board - a bit like flashing firmware on your mobile phone. Havent tried it myself, figure you have little to lose. Especially after 1 blink if you can see the SDcard from the other end of your OTG cable that would be hugely encouraging.
I have updated the wiki about the SPI jumper - again worth a shout IMHO just to eliminate any crud that may have happened to your SPI. (And far more useful than the github flash/erase page you linked: that requires your Rockpro64 to be running and so far we are not sure of that!) But again RJ45 lights give hope it has not stopped breathing yet!
RE: Hardware issue overheating while booting and fail to boot - by dukla2000 - 08-21-2018, 01:31 PM
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 10,693 06-21-2025, 06:21 AM
Last Post: aleksei
  enble boot after power loss/restore dkebler 18 20,994 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 183,219 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 3,063 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 9,865 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 9,870 05-18-2023, 10:46 AM
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 3,194 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  u-boot locked on pine64pro ljones 1 3,214 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 15,235 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 2,357 07-19-2022, 10:48 PM
Last Post: hazz
