Ethernet network keeps dropping!
Greeting to all the forumers,
I am somehow very frustrated in my purchase of the Rock64.
I thoughty it is straightforward to install and use Libreelec.
I did successfull install it, but it kept crashing!
I decided to gives Kodi on Androidf a try. I flashed the (android-7.1-rock-64-rock64_atv-v0.3.13-r115-update.zip) image. Everything went fine, but the Ethernet connection keeps dropping!
I tried to have a static IP address instead of using DHCP for no better result!
Any advice on how to resolve this matter?
I also would like to ask if anybody had successfully managed to have higher than 1920x1080p/60 resolution?
Thanks for your help.
Naass
Ethernet network keeps dropping! - by Naass - 08-18-2018, 08:30 AM
RE: Ethernet network keeps dropping! - by Naass - 08-19-2018, 01:04 PM
Ethernet network keeps dropping! - by Naass - 08-24-2018, 12:35 PM
  2nd ethernet in ROCK64 with android daniele 0 2,813 12-04-2017, 04:30 AM
Last Post: daniele
Sad Rock64 has not Ethernet LAN dhruan 31 46,414 09-03-2017, 10:14 PM
Last Post: Xiyl
