Regular Android build for Rock64?
(12-01-2018, 05:15 AM)lumix14 Wrote:
(11-02-2018, 11:46 PM)insanescouter Wrote:
(11-02-2018, 05:49 PM)Pepe Wrote:
(08-24-2018, 03:35 PM)tllim Wrote:
(08-18-2018, 06:53 AM)fender90 Wrote: Why don't you make a regular Android build for Rock64?
There is no technical limitation. The ROCK64 using TV UI due to the primary video output is connected to TV.
Because there is no Android build without TV UI, are you planning to do one? Not many apps in this country support Android TV and they need side-load, and that's why I prefer regular Android, where the apps can be downloaded via Google Play.
Is there a way to remove the tv ui after its installed?
If you are referring to the UI, I am using nova launcher now , perfectly happy with that.
I tired using a launcher. Still there is no status bar or navigation bar, settings menu is different. It's not touchscreen friendly at all. I guess if they at least modify the systemui.apk and add status bar and navigation bar there will be no need to develop a regular Android build at all. Simply changing the launcher would solve almost all the problems (except the different settings menu which is not that terrible)
Regular Android build for Rock64? - by fender90 - 08-18-2018, 06:53 AM
RE: Regular Android build for Rock64? - by tllim - 08-24-2018, 03:35 PM
RE: Regular Android build for Rock64? - by Pepe - 11-02-2018, 05:49 PM
RE: Regular Android build for Rock64? - by fender90 - 12-01-2018, 12:48 PM
RE: Regular Android build for Rock64? - by dudemo - 08-29-2018, 02:52 PM
RE: Regular Android build for Rock64? - by dudemo - 08-31-2018, 07:01 PM
  Android Images (ROCK64) pineadmin 77 224,527 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 11,202 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 11,435 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 9,841 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 7,523 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 6,387 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 5,667 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 9,680 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 4,592 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 7,675 09-18-2020, 07:58 PM
Last Post: BowerR64
