Regular Android build for Rock64?
(08-29-2018, 02:52 PM)dudemo Wrote:
(08-26-2018, 08:48 AM)fender90 Wrote: So the question is if there are any plans to release a regular version of Android for this board?
The ROCKPro64 is supposed to be getting a stock version of Android, so perhaps you might want to update to that board? It also has the benefit of long-term support, something that the Rock64 doesn't have and as such will probably be dropped from development soon enough.
I don't believe the Rock64 Development will be totally dropped as LibreELEC OS is being actively tested and developed with Rockchip employees participating. Android and Android TV Development is probably an unknown. Depending on your needs, the RockPro may be overkill when making a purchase decision. I've been using Ayufans' Android TV on my Rock64 eMMC and LibreELEC via SD Card Boot. Suits my needs.
Regular Android build for Rock64? - by fender90 - 08-18-2018, 06:53 AM
RE: Regular Android build for Rock64? - by tllim - 08-24-2018, 03:35 PM
RE: Regular Android build for Rock64? - by Pepe - 11-02-2018, 05:49 PM
RE: Regular Android build for Rock64? - by dudemo - 08-29-2018, 02:52 PM
RE: Regular Android build for Rock64? - by kostaman - 08-31-2018, 06:34 PM
RE: Regular Android build for Rock64? - by dudemo - 08-31-2018, 07:01 PM
  Android Images (ROCK64) pineadmin 77 227,368 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 11,504 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 11,640 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 10,091 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 7,684 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 6,484 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 5,765 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 9,838 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 4,709 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 7,818 09-18-2020, 07:58 PM
Last Post: BowerR64
