Regular Android build for Rock64?
(08-18-2018, 06:53 AM)fender90 Wrote: Dear Pine64 team! Why don't you make a regular Android build for Rock64? The TV UI in the stock OS is almost unusable with touchscreens. No navbar and status bar so it is very inconvenient to connect to network or adjust the volume. I just don't get it. Are there any TECHNICAL limitations for rk3328 for making a regular android os? Rock64 is a really great product and has a great hardware but the software side is a lot of pain
There is no technical limitation. The ROCK64 using TV UI due to the primary video output is connected to TV.
Regular Android build for Rock64? - by fender90 - 08-18-2018, 06:53 AM
RE: Regular Android build for Rock64? - by tllim - 08-24-2018, 03:35 PM
RE: Regular Android build for Rock64? - by Pepe - 11-02-2018, 05:49 PM
RE: Regular Android build for Rock64? - by dudemo - 08-29-2018, 02:52 PM
RE: Regular Android build for Rock64? - by dudemo - 08-31-2018, 07:01 PM
  Android Images (ROCK64) pineadmin 77 236,167 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 12,312 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 12,594 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 10,849 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,187 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 6,924 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,173 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 10,518 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,116 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,328 09-18-2020, 07:58 PM
Last Post: BowerR64
