WiFi module causes boot loop
(04-14-2016, 04:54 AM)SkairkrohBule Wrote:
(04-14-2016, 03:42 AM)BnEc Wrote:
(04-14-2016, 03:37 AM)DaveyDarko Wrote: Make sure you are getting enough power, I could foresee a scenario were the WiFi/BT module is drawing enough that, when added to the rest of the boards load, might overwhelm your supply and thus fail. Just a thought before sending it back.
Hi Davey,
Thanks for the reply, I'm currently using a 5v 2.4A power supply, as I have been struggling to get any joy with anything lower. I'll have to have a look around and see if I have a larger 5v charger.
You shouldn't need more than 2 amps of current at 5 volts. I think the issue lies elsewhere. Perhaps the WiFi module is faulty, or could be a software issue.
I'll have to invest in a true 5v 2 amp charge then I think.
WiFi module causes boot loop - by BnEc - 04-14-2016, 01:51 AM
RE: WiFi module causes boot loop - by DaveyDarko - 04-14-2016, 03:37 AM
RE: WiFi module causes boot loop - by BnEc - 04-14-2016, 03:42 AM
RE: WiFi module causes boot loop - by Ghost - 04-14-2016, 04:54 AM
RE: WiFi module causes boot loop - by rahlquist - 04-14-2016, 05:50 AM
RE: WiFi module causes boot loop - by BnEc - 04-14-2016, 05:27 AM
RE: WiFi module causes boot loop - by BnEc - 04-14-2016, 07:21 AM
RE: WiFi module causes boot loop - by Ghost - 04-14-2016, 08:00 AM
RE: WiFi module causes boot loop - by BnEc - 04-15-2016, 04:24 PM
RE: WiFi module causes boot loop - by tllim - 04-17-2016, 08:45 AM
RE: WiFi module causes boot loop - by bpcoyo - 04-22-2016, 01:30 PM
RE: WiFi module causes boot loop - by tllim - 04-22-2016, 04:36 PM
RE: WiFi module causes boot loop - by bpcoyo - 04-23-2016, 05:34 PM
RE: WiFi module causes boot loop - by bpcoyo - 04-22-2016, 03:50 PM
RE: WiFi module causes boot loop - by BnEc - 04-25-2016, 03:00 PM
RE: WiFi module causes boot loop - by tllim - 04-26-2016, 02:04 PM
RE: WiFi module causes boot loop - by pfeerick - 09-24-2016, 09:12 PM
  Wifi dongle issues Deckard 2 776 01-13-2025, 12:34 PM
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 2,884 12-10-2024, 07:23 PM
Last Post: Dendrocalamus64
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 1,156 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 2,238 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 2,910 05-24-2023, 02:45 AM
Last Post: draintroup
  USB adapter to eMMC module not recognized danril 0 2,170 11-25-2022, 04:16 AM
Last Post: danril
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 2,258 10-06-2022, 08:46 PM
Last Post: ihab
Exclamation Quartz64 model a wont boot AndyNZAUS 0 2,234 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 3,938 02-02-2021, 12:13 AM
Last Post: PineSupporter
  How to boot from SD card on pinebook pro linux123 3 7,769 12-02-2020, 10:29 AM
Last Post: linux123
