How to handle a Pine64 correctly
I think many of the Backers are not used to handle unprotected highly integrated electronic PCB's without encapsulation.
There are several issues to consider, but first of all:
Electrostatic protection:
The board and component added to the PCB (Printed circuit Board) can be very sensitive to electrostatic discharges.
Sources of electrostatic discharges can be YOU or the materials you use together with the Pine 64.
If the Pine 64 is exposed to electrostatic discharges can the result be a defect Pine 64 - ether immediately or latent - waiting for a moment when it is absolutely not wanted or expected to fail.
Protect it against electrostatic discharges. The board comes wrapped into a anti electrostatic bag and whenever you handle the board makes sure that you and where you place it have the same electrostatic potential as the Pine 64.
If possible, handle it at a protective work space away from chargeable materials like carpets, nylon, plastic bags etc.
When you want to remove it from the bag, place it on a protective surface (e.g. on top of the anti static bag).
If you do not have an electrostatic save work desk (I do not suppose you have!) use a table made of non conductive materials ( e.g. wood or glass. Cardboard is also usable) but keep it away from electrostatic chargeable materials like nylon. Also think about what you wear. Prefer cotton, avoid synthetic materials.
Discharge your hand by touching the work area and the Pines anti static back. When removing it from the bas, grab it by one of the metallic connectors and the edges of the PCB. Avoid to touch the electronic circuits. (Both with and without power connected to the board.)
Make sure your pine and your other connected equipment have the same electrical potential. Use the ground / shield connections for this. If possible mount it into a conductive box (isolated from it naturally ) connect the GND or shield to the box. Thereby will you protect against electrostatic discharges but also limit the HF radiation from the Pine a bit.
How to handle a Pine64 correctly - by gbjensen - 04-13-2016, 12:42 PM
  Just discovered Pine64 ! - first Q philip_rhoades 4 507 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 293 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 42,566 01-15-2020, 12:46 PM
  Emails from pine64 received as spam by gmail Matan 2 398 08-21-2019, 08:30 AM
Last Post: Leiaz
Information Creating a NAS server in Pine64 javi_cala 4 2,478 01-21-2019, 02:03 AM
Last Post: bartes
  The 6 most common reasons why Pine64 won't boot Andrew2 109 79,666 10-11-2018, 11:35 PM
Last Post: Technolab88
  Pine64 installer way slow flashing Paraplegic Racehorse 2 636 01-10-2018, 04:05 PM
Last Post: dkryder
  Pine64 Ubuntu Mate No Sound adamjedgar 3 1,234 11-06-2017, 02:53 AM
Last Post: Luke
  Upgrading Memory on PINE64 + 2GB Osh818 2 1,514 04-24-2017, 10:12 PM
Last Post: Osh818
  Mini-Tutorial to get a linux Desktop GUI working on Pine64+ speedro86 15 9,249 04-05-2017, 01:45 PM
Last Post: speedro86
