Arch Linux on RockPro64
#22
(11-24-2018, 04:09 AM)mmatyas Wrote: When you look into his PKGBUILD in his sources, you can find the link to the linux kernel resources he used to get the kernel sources from.
Finally got around to trying my hand at compiling a kernel and installing it. This worked, but (after an afternoon of trying) I never got the kernel to work.
What I did was the following:
- clone your repo (https://github.com/matyas1995/linux-aarch64-rockpro64),
- update the 'PKGBUILD' and 'linux-rockpro64.install' files to fetch and build the latest release (4.20.0-1083, commit),
- run 'makepkg', answer 'y' and 'n' to the inclusion of some modules (following the suggested answers mostly) and wait for approx 1h for the compiling to finish (also applied your tip of setting MAKEFLAGS to "-j7"),
- install the newly made package ('pacman -U linux-rockpro64-4.20.0-1083-aarch64.pkg.tar.xz'),
- and finally, change '/boot/extlinux/extlinux.conf' to:
cat /boot/extlinux/extlinux.conf.new
timeout 10
default arch
menu title select kernel
label arch
   kernel /boot/Image
   initrd /boot/initramfs-linux.img
   devicetreedir /boot/dtbs
   append rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=${ethaddr} eth1addr=${eth1addr} serial=${serial#} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 root=LABEL=linux-root rootwait rootfstype=ext4
After that I rebooted the system. Sadly it did not come up anymore. To see what was happening I attached the rockpro directly to my laptop through GPIO>USB with a serial console and watched the startup messages scroll by. I think the following bit is interesting:
[    2.973624] RAMDISK: Couldn't find valid RAM disk image starting at 0.
[    2.974239] Waiting for root device LABEL=linux-root...
... end then it basically stops.
It complains that it can't find the RAMDISK. This is odd, because in the beginning of the startup progress, before attempting to start the kernel, it states this:
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:7...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
379 bytes read in 112 ms (2.9 KiB/s)
select kernel
1:      arch
Enter choice: 1:        arch
Retrieving file: /boot/initramfs-linux.img
5685385 bytes read in 303 ms (17.9 MiB/s)
Retrieving file: /boot/Image
32614912 bytes read in 1484 ms (21 MiB/s)
append: rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=xxx eth1addr= serial=xxx cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 root=LABEL=linux-root rootwait rootfstype=ext4
Retrieving file: /boot/dtbs/rockchip/rk3399-rockpro64.dtb
55324 bytes read in 269 ms (200.2 KiB/s)
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f5997000, end f5f03089 ... OK
   Loading Device Tree to 00000000f5986000, end 00000000f599681b ... OK
Also, the message right after, Waiting for root device LABEL=linux-root..., is odd because this is still partition 6, which still has the right label (I double checked by running 'blkid').
So it seems as if it correctly finds and reads the extlinux config, finds the images, and loads them into memory; and then seems to forget about it later during the actual booting of the kernel.
Does anyone have any idea what I'm doing wrong?
PinePhone (BH 2GB + CE 3GB) // RockPro64 4GB (rev. 2.1) - OMV NAS // PineH64 3GB (model B) - off-prem OMV NAS // Pine64-LTS 2GB (rev. 1.2 + Playbox) - Domotics server
Arch Linux on RockPro64 - by mmatyas - 07-29-2018, 03:31 PM
RE: Arch Linux on RockPro64 - by Tigger - 08-06-2018, 01:29 PM
RE: Arch Linux on RockPro64 - by hiccupstix - 08-06-2018, 03:40 PM
RE: Arch Linux on RockPro64 - by Tigger - 08-07-2018, 03:02 AM
RE: Arch Linux on RockPro64 - by mmatyas - 08-08-2018, 01:49 AM
Arch Linux on RockPro64 - by hiccupstix - 08-07-2018, 03:17 AM
RE: Arch Linux on RockPro64 - by Tigger - 08-08-2018, 04:48 AM
RE: Arch Linux on RockPro64 - by ah- - 08-28-2018, 03:14 PM
RE: Arch Linux on RockPro64 - by dukla2000 - 08-29-2018, 03:37 AM
RE: Arch Linux on RockPro64 - by ah- - 08-29-2018, 11:25 AM
RE: Arch Linux on RockPro64 - by ali - 11-09-2018, 08:54 AM
RE: Arch Linux on RockPro64 - by mmatyas - 11-06-2018, 03:47 PM
RE: Arch Linux on RockPro64 - by mmatyas - 11-20-2018, 06:29 PM
RE: Arch Linux on RockPro64 - by ali - 11-27-2018, 12:28 AM
RE: Arch Linux on RockPro64 - by p1x3l3d - 11-22-2018, 05:28 PM
RE: Arch Linux on RockPro64 - by mmatyas - 11-24-2018, 04:09 AM
RE: Arch Linux on RockPro64 - by p1x3l3d - 11-26-2018, 02:11 PM
RE: Arch Linux on RockPro64 - by p1x3l3d - 01-13-2019, 12:41 PM
RE: Arch Linux on RockPro64 - by mmatyas - 01-19-2019, 11:30 AM
RE: Arch Linux on RockPro64 - by mmatyas - 11-27-2018, 01:21 AM
RE: Arch Linux on RockPro64 - by ali - 12-01-2018, 07:16 AM
RE: Arch Linux on RockPro64 - by fosf0r - 12-03-2018, 09:59 AM
RE: Arch Linux on RockPro64 - by ali - 01-11-2019, 02:21 AM
RE: Arch Linux on RockPro64 - by mmatyas - 02-26-2019, 11:31 AM
RE: Arch Linux on RockPro64 - by mmatyas - 02-27-2019, 06:07 PM
RE: Arch Linux on RockPro64 - by mmatyas - 09-10-2019, 01:58 PM
RE: Arch Linux on RockPro64 - by oreggin - 09-26-2019, 03:09 PM
RE: Arch Linux on RockPro64 - by TaborFife - 09-28-2019, 04:30 AM
RE: Arch Linux on RockPro64 - by hev - 03-20-2020, 12:27 AM
RE: Arch Linux on RockPro64 - by rhysperry111 - 05-23-2020, 02:29 PM
RE: Arch Linux on RockPro64 - by mmatyas - 05-30-2020, 12:08 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 462 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 708 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,607 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 825 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,306 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 83,059 08-11-2023, 11:13 AM
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,286 07-14-2023, 04:22 AM
Last Post: hunderteins
  How to enable CoreSight ETM trace on RockPro64 shpark 0 579 05-21-2023, 11:34 PM
Last Post: shpark
  Linux laptop does not detect the board when plugged in via USB soupy 1 3,995 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Rockpro64 Dead on arrival? quixoticgeek 1 944 03-12-2023, 06:55 PM
Last Post: quixoticgeek
