Arch Linux on RockPro64
Hey, I did the same and installed Arch by modifying one of the Ubuntu images. It doesn't seem too far off to have a straight up Arch port, I think the only bit that's actually left over from the Ubuntu image now is u-boot.
It runs nicely with the default 4.4 ayufan kernel that came with Ubuntu. Surprisingly the 4.18.5 arch mainline kernel came up and even had ethernet, but a bunch of other hardware didn't work, I guess partially due to the missing dtb, partially due to patches not yet in mainline.
Right now I'm running the ayufan 4.18.0-rc8, compiled via https://github.com/ah-/PKGBUILDs (https://github.com/ah-/PKGBUILDs/commit/...bb9839edd0), see core/linux-rockpro64 and just run makepkg in there. After installing the packages you'll need to add the kernel to extlinux.conf:
label arch
kernel /boot/Image
initrd /boot/initramfs-linux.img
devicetreedir /boot/dtbs
append rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=${ethaddr} eth1addr=${eth1addr} serial=${serial#} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 root=LABEL=linux-root rootwait rootfstype=ext4
With that it runs really nicely as a server, it's fast and all the hardware I'm using works, including pcie sata.
The HDMI port works somewhat, I get an image but the UI is really slow, I don't get full resolution and the image is quite noisy. I suspect this might be due to me not having any userland installed for the GPU, does anyone know what the Mali GPU needs and how t get it onto Arch?
Arch Linux on RockPro64 - by mmatyas - 07-29-2018, 03:31 PM
RE: Arch Linux on RockPro64 - by Tigger - 08-06-2018, 01:29 PM
RE: Arch Linux on RockPro64 - by hiccupstix - 08-06-2018, 03:40 PM
RE: Arch Linux on RockPro64 - by Tigger - 08-07-2018, 03:02 AM
RE: Arch Linux on RockPro64 - by mmatyas - 08-08-2018, 01:49 AM
Arch Linux on RockPro64 - by hiccupstix - 08-07-2018, 03:17 AM
RE: Arch Linux on RockPro64 - by Tigger - 08-08-2018, 04:48 AM
RE: Arch Linux on RockPro64 - by ah- - 08-28-2018, 03:14 PM
RE: Arch Linux on RockPro64 - by dukla2000 - 08-29-2018, 03:37 AM
RE: Arch Linux on RockPro64 - by ah- - 08-29-2018, 11:25 AM
RE: Arch Linux on RockPro64 - by ali - 11-09-2018, 08:54 AM
RE: Arch Linux on RockPro64 - by mmatyas - 11-06-2018, 03:47 PM
RE: Arch Linux on RockPro64 - by mmatyas - 11-20-2018, 06:29 PM
RE: Arch Linux on RockPro64 - by ali - 11-27-2018, 12:28 AM
RE: Arch Linux on RockPro64 - by p1x3l3d - 11-22-2018, 05:28 PM
RE: Arch Linux on RockPro64 - by mmatyas - 11-24-2018, 04:09 AM
RE: Arch Linux on RockPro64 - by p1x3l3d - 11-26-2018, 02:11 PM
RE: Arch Linux on RockPro64 - by p1x3l3d - 01-13-2019, 12:41 PM
RE: Arch Linux on RockPro64 - by mmatyas - 01-19-2019, 11:30 AM
RE: Arch Linux on RockPro64 - by mmatyas - 11-27-2018, 01:21 AM
RE: Arch Linux on RockPro64 - by ali - 12-01-2018, 07:16 AM
RE: Arch Linux on RockPro64 - by fosf0r - 12-03-2018, 09:59 AM
RE: Arch Linux on RockPro64 - by ali - 01-11-2019, 02:21 AM
RE: Arch Linux on RockPro64 - by mmatyas - 02-26-2019, 11:31 AM
RE: Arch Linux on RockPro64 - by mmatyas - 02-27-2019, 06:07 PM
RE: Arch Linux on RockPro64 - by mmatyas - 09-10-2019, 01:58 PM
RE: Arch Linux on RockPro64 - by oreggin - 09-26-2019, 03:09 PM
RE: Arch Linux on RockPro64 - by TaborFife - 09-28-2019, 04:30 AM
RE: Arch Linux on RockPro64 - by hev - 03-20-2020, 12:27 AM
RE: Arch Linux on RockPro64 - by rhysperry111 - 05-23-2020, 02:29 PM
RE: Arch Linux on RockPro64 - by mmatyas - 05-30-2020, 12:08 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 517 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 739 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,659 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 851 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,546 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 83,722 08-11-2023, 11:13 AM
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,335 07-14-2023, 04:22 AM
Last Post: hunderteins
  How to enable CoreSight ETM trace on RockPro64 shpark 0 602 05-21-2023, 11:34 PM
Last Post: shpark
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,025 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Rockpro64 Dead on arrival? quixoticgeek 1 973 03-12-2023, 06:55 PM
Last Post: quixoticgeek
