UART connection
(08-13-2018, 07:55 AM)martinayotte Wrote:
(08-12-2018, 11:18 AM)Yoast Wrote: Screen works (as well as minicom and picocom).
Which version of picocom works for you ?
Mine, v1.7, gives me "FATAL: failed to add device /dev/ttyUSB0: Invalid baud rate" ...
[root@mbp_arch ~]# picocom --help
picocom v3.1
Compiled-in options:
 TTY_Q_SZ is 0
 HIGH_BAUD is enabled
 USE_FLOCK is enabled
 LINENOISE is enabled
 HISTFILE is: .picocom_history
 USE_CUSTOM_BAUD is enabled
Most likely the compile options USE_CUSTOM_BAUD and HIGH_BAUD are needed to enable the 1.5M baud rate...
UART connection - by catalinii - 07-26-2018, 10:17 PM
RE: UART connection - by evilbunny - 07-26-2018, 10:51 PM
RE: UART connection - by catalinii - 07-27-2018, 07:57 PM
RE: UART connection - by Bullet64 - 07-28-2018, 12:35 AM
RE: UART connection - by frewind - 07-28-2018, 04:15 AM
RE: UART connection - by Bullet64 - 07-28-2018, 04:21 AM
RE: UART connection - by catalinii - 08-04-2018, 10:20 PM
RE: UART connection - by paradise - 08-04-2018, 10:35 PM
RE: UART connection - by martinayotte - 08-06-2018, 06:55 AM
RE: UART connection - by catalinii - 08-09-2018, 09:41 PM
RE: UART connection - by martinayotte - 08-10-2018, 07:43 AM
RE: UART connection - by Yoast - 08-12-2018, 11:18 AM
RE: UART connection - by martinayotte - 08-13-2018, 07:55 AM
RE: UART connection - by Yoast - 08-13-2018, 11:01 AM
RE: UART connection - by Apokalypz - 08-26-2018, 08:46 PM
RE: UART connection - by catalinii - 08-27-2018, 06:02 AM
