0.7.9 Linux release from ayufan
#35
Quote: it is a question if I can work around the limitations. e.g. also lots of modules missing in Ayufan rc builds, e.g. btusb
You could just try to build the kernel with the modules you need yourself in order to try them out. It's pretty easy. Just git clone ayufan's linux-mainline repo, apt-get install gcc and friends (if you haven't already), run 'make menuconfig', select Y or M for the stuff you need, then build with 'make -j6 bindeb-pkg'. The package will be in the parent folder and can just be installed as usual with dpkg -i. Thanks to the work of the maintainers of this image it will even take care of modifying extlinux.conf. If you mess it up you can just go back to the old kernel by editing extlinux.conf manually or choosing a dfiferent kernel via serial console.
0.7.9 Linux release from ayufan - by Luke - 07-24-2018, 03:31 PM
RE: 0.7.8 Linux release from ayufan - by ab1jx - 07-24-2018, 04:52 PM
RE: 0.7.8 Linux release from ayufan - by Luke - 07-25-2018, 03:52 AM
RE: 0.7.8 Linux release from ayufan - by ab1jx - 07-27-2018, 06:09 PM
RE: 0.7.8 Linux release from ayufan - by ab1jx - 07-28-2018, 06:36 AM
RE: 0.7.9 Linux release from ayufan - by Luke - 07-30-2018, 05:01 AM
RE: 0.7.9 Linux release from ayufan - by ab1jx - 08-05-2018, 02:37 PM
RE: 0.7.9 Linux release from ayufan - by ab1jx - 08-06-2018, 09:45 AM
RE: 0.7.9 Linux release from ayufan - by ab1jx - 08-06-2018, 11:17 AM
RE: 0.7.9 Linux release from ayufan - by lucho - 08-07-2018, 03:41 AM
RE: 0.7.9 Linux release from ayufan - by lucho - 08-09-2018, 05:08 AM
RE: 0.7.9 Linux release from ayufan - by ab1jx - 08-07-2018, 04:45 PM
RE: 0.7.9 Linux release from ayufan - by ab1jx - 08-07-2018, 08:15 PM
RE: 0.7.9 Linux release from ayufan - by ab1jx - 08-07-2018, 06:35 PM
RE: 0.7.9 Linux release from ayufan - by ab1jx - 08-07-2018, 06:56 PM
RE: 0.7.9 Linux release from ayufan - by ab1jx - 08-08-2018, 01:44 PM
RE: 0.7.9 Linux release from ayufan - by Bullet64 - 08-08-2018, 09:24 PM
RE: 0.7.9 Linux release from ayufan - by Deathcrow - 09-08-2018, 06:55 AM
RE: 0.7.9 Linux release from ayufan - by festor89 - 11-16-2018, 03:54 PM
RE: 0.7.9 Linux release from ayufan - by festor89 - 11-17-2018, 02:35 AM
RE: 0.7.9 Linux release from ayufan - by Bullet64 - 11-17-2018, 03:26 AM
RE: 0.7.9 Linux release from ayufan - by nuumio - 11-19-2018, 08:04 AM
RE: 0.7.9 Linux release from ayufan - by nuumio - 12-04-2018, 02:03 PM
RE: 0.7.9 Linux release from ayufan - by Luke - 02-25-2019, 02:55 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 10 17,518 11-26-2025, 02:45 PM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 4,341 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 6,076 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 7,252 04-23-2023, 01:32 PM
Last Post: diederik
  Linux laptop does not detect the board when plugged in via USB soupy 1 6,593 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 linux console video mode callegar 0 2,231 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 15,092 04-30-2022, 03:57 PM
Last Post: TRS-80
  Armbian 22.02 Release Announcement TRS-80 0 2,370 02-28-2022, 05:08 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 9,108 01-03-2022, 10:32 AM
Last Post: whitecat23
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 2,734 07-24-2021, 09:46 PM
Last Post: Mentaluproar
