u-boot (forks) status
simonsouth
Quote:I'll write up a lengthier tutorial when I'm done but to start using the mainline version of U-Boot, assuming you have the prerequisites taken care of (the cross-compilation toolchain installed if needed, the ARM Trusted Firmware BL31 built and the CROSS_COMPILE and BL31 environment variables set appropriately), you'll need to ....
Thanks, simonsouth, for your primer.  Looking forward to the lengthier version if you ever find time.
I want to boot a efi_stub enabled kernel, and this 2017 u-boot doesn't know the "efidebug" command, which is necessary, according to these instructions.  Your tutorial is encouraging enough to proceed to try and build and upgrade u-boot.
u-boot (forks) status - by mcerveny - 07-21-2018, 06:51 PM
RE: u-boot (forks) status - by asavah - 07-28-2018, 12:28 PM
RE: u-boot (forks) status - by mcerveny - 07-28-2018, 02:05 PM
RE: u-boot (forks) status - by asavah - 07-28-2018, 02:58 PM
RE: u-boot (forks) status - by ayufan - 07-30-2018, 03:54 PM
RE: u-boot (forks) status - by simonsouth - 10-14-2019, 09:55 AM
RE: u-boot (forks) status - by globaltree - 08-27-2020, 01:44 PM
RE: u-boot (forks) status - by ayufan - 10-14-2019, 12:50 PM
RE: u-boot (forks) status - by kuleszdl - 03-21-2020, 03:21 PM
RE: u-boot (forks) status - by CameronNemo - 05-11-2020, 01:23 PM
RE: u-boot (forks) status - by XmAz - 06-19-2020, 03:37 PM
RE: u-boot (forks) status - by XmAz - 06-19-2020, 03:40 PM
RE: u-boot (forks) status - by CameronNemo - 08-08-2020, 12:05 PM
RE: u-boot (forks) status - by tophneal - 08-08-2020, 01:50 PM
RE: u-boot (forks) status - by CameronNemo - 08-08-2020, 03:55 PM
  Rock64 won't boot luminosity7 10 15,515 03-16-2024, 08:33 AM
Last Post: dmitrymyadzelets
  Rock64 doesn't boot dstallmo 1 3,829 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 5,047 02-29-2024, 02:12 PM
Last Post: reukiodo
  ROCK64 v3 can it boot from USB? Tsagualsa 4 8,621 11-29-2022, 11:31 AM
Last Post: Macgyver
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 3,974 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  boot hdd usb3 philipe 1 4,389 01-27-2021, 02:12 PM
  Sent support order status , no responses RockPro64Newbie 3 8,714 01-19-2021, 12:09 PM
Last Post: mathygreen
  Libreelec Rock64 - 4GB no boot spiker15 3 7,123 11-02-2020, 12:36 AM
Last Post: wilsonYan
  Rock64 - boot helpmerock 2 5,321 10-08-2020, 01:29 PM
Last Post: helpmerock
  No boot up after power on Whoopsadaisy 4 8,582 09-26-2020, 05:14 PM
Last Post: simonsouth
