Compatible eMMC modules and benchmarks
(07-12-2018, 11:37 AM)danboid Wrote: I ordered my rock64 a few days ago but I'm not expecting it to arrive for a few weeks yet as I live in the UK.
I ordered a 32GB eMMC from a UK electronics company but I got sent a chip, not a module that would work with the rock64 so I'm having to return it. They had no pictures of it on their site so I didn't know what it was until it arrived.
I've read on this forum that the rock64 is compatible with odroid emmc modules but which odroid model is the rock64 (most) compatible with? odroid.co.uk sells emmc modules for the odroid C1/C1+, C2 or XU3/XU4. I'm not sure if these modules all have different connectors or if its just different software pre-loaded onto them?
Is there anywhere else is the UK or Europe apart from odroid.co.uk and allo that sells emmc modules? Is there a best brand or model to look for? Has anyone done any benchmarks of different emmc modules with the rock64? Tell me everything I might need to know about emmcs and the rock64 please, the rock64/pine64 page doesn't tell us much about this.
There is no universal standard for eMMC sockets - just so you know.
Yes, sure, some odroid eMMC modules are compatible and will work (I have one for the C2 that works just fine) with the PINE64 boards; including the Rock64. I will not speculate on here which of the odroid modules will and which will not work because I do not wish to give you a false impression that compatibility is guaranteed.
As for the benchmarks, they are out there if you google ... in short, Ordoid's high prices reflect higher performance.
RE: Compatible eMMC modules and benchmarks - by Luke - 07-12-2018, 01:52 PM
Question Have eMMC adapter - but can't seem to fix eMMC card SirRyanTheGeek 3 6,113 05-04-2019, 04:19 AM
Last Post: burito111
  emmc module help default_user8 1 2,870 04-05-2019, 07:19 PM
Last Post: SirRyanTheGeek
  Dead eMMC? machina 8 9,198 11-21-2018, 05:05 AM
Last Post: machina
  FORSEE eMMC is reliable? ramprasad 3 5,062 11-12-2018, 03:34 PM
Last Post: Tortax
  can a SD card be used as storage with emmc boot Enzo 9 12,351 05-10-2018, 08:53 PM
Last Post: pfeerick
  Flashing full image to eMMc with a mSD card to eCMM adapter pytheas 2 3,802 04-09-2018, 03:56 AM
Last Post: Luke
  None of my Wifi modules work NicoD 7 8,932 04-05-2018, 02:53 PM
  Prb booting emmc darthyoh 12 13,184 03-22-2018, 07:07 PM
Last Post: pfeerick
  eMMC angelscream09 2 3,819 02-05-2018, 08:36 AM
Last Post: Luke
  Were do you get compatible emmc modules? Rar9 1 3,085 12-09-2017, 03:16 AM
Last Post: gkkpch
