PCIe -> SATA and NVMe work as of 0.6.59
(07-25-2018, 12:47 PM)dukla2000 Wrote:
(07-25-2018, 05:17 AM)Bullet64 Wrote: Look -> https://gist.github.com/ayufan/30c46381c...4a752946db
He is using an Samsung PM961
I did see on his lspci output it was reported as
"Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961", but pfeerick 960 EVO output is identical.
My limited insight to Samsung 960 NVMe devices indicates SM961 and PM961 devices were released to OEMs early in 2016. And Samsung later released EVO and PRO versions for the general public. However, as per Anandtech there are differences in the NAND chips which is what I expect explains the difference in iozone numbers from ayufan and pfeerick?
If the table at Anandtech is accurate then actual PM961 devices should be the slowest of the lot.
I remember, that Ayufan postet that he has an 960 Pro. But that is only from my memory, I can be wrong too. Waiting for Ayufan...
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
PCIe -> SATA and NVMe work as of 0.6.59 - by Luke - 07-04-2018, 09:37 AM
RE: PCIe -> SATA and NVMe work as of 0.6.59 - by Bullet64 - 07-25-2018, 01:27 PM
  RK3399 PCIe enumeration jhadd 0 2,021 01-31-2024, 08:56 AM
Last Post: jhadd
Question nand-sata-install on RAID-1 array ARMandHammer 1 2,479 02-12-2023, 03:10 AM
Last Post: igorp
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 5,014 10-14-2022, 06:24 AM
Last Post: rwk-
  Need help! Can't get device mode to work. scanboy 6 8,533 12-29-2021, 08:35 PM
Last Post: djonathan
  No PCIe controller detected... Limhes 1 2,851 11-23-2021, 06:23 AM
Last Post: Limhes
  Using the PCIe slot of ROCKPro64 as EndPoint mode nonoriri 1 3,076 11-20-2021, 10:53 AM
Last Post: fire219
  WiFi not working with PCIe SSD installed mikeD 0 2,241 05-25-2021, 07:48 AM
Last Post: mikeD
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 10,751 05-20-2021, 10:04 PM
Last Post: t4_4t
  Booting from NVME ilovegentoo 11 17,663 05-10-2021, 02:06 PM
Last Post: rrowles2000
  Upgrade Debian kernel on a SD/SATA drive boot combo. linuxha 6 11,815 12-12-2019, 04:43 AM
Last Post: dukla2000
