PCIe -> SATA and NVMe work as of 0.6.59
(07-25-2018, 04:48 AM)dukla2000 Wrote:
(07-17-2018, 11:31 PM)pfeerick Wrote: I bit the bullet and got a Samsung 960 EVO M.2 drive, which works OOTB with 0.7.6 (as it's the current pre-release build) with the stock 4.4 kernel:
Nice :-)
Any idea why your top end is different to ayufan? He also has Samsung, I am not sure which precise model/size though. Or which release/kernel he was testing on to get 1.4G (you got 1.1G)
Last - do you have an eMMC? If so what size and how is it on iozone please?
My Rp64 now in the post - figure lashing out on nVME before it arrives would be a bit previous!
TIA
Look -> https://gist.github.com/ayufan/30c46381c...4a752946db
He is using an Samsung PM961
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
PCIe -> SATA and NVMe work as of 0.6.59 - by Luke - 07-04-2018, 09:37 AM
RE: PCIe -> SATA and NVMe work as of 0.6.59 - by Bullet64 - 07-25-2018, 05:17 AM
  RK3399 PCIe enumeration jhadd 0 2,026 01-31-2024, 08:56 AM
Last Post: jhadd
Question nand-sata-install on RAID-1 array ARMandHammer 1 2,485 02-12-2023, 03:10 AM
Last Post: igorp
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 5,030 10-14-2022, 06:24 AM
Last Post: rwk-
  Need help! Can't get device mode to work. scanboy 6 8,572 12-29-2021, 08:35 PM
Last Post: djonathan
  No PCIe controller detected... Limhes 1 2,856 11-23-2021, 06:23 AM
Last Post: Limhes
  Using the PCIe slot of ROCKPro64 as EndPoint mode nonoriri 1 3,084 11-20-2021, 10:53 AM
Last Post: fire219
  WiFi not working with PCIe SSD installed mikeD 0 2,244 05-25-2021, 07:48 AM
Last Post: mikeD
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 10,792 05-20-2021, 10:04 PM
Last Post: t4_4t
  Booting from NVME ilovegentoo 11 17,746 05-10-2021, 02:06 PM
Last Post: rrowles2000
  Upgrade Debian kernel on a SD/SATA drive boot combo. linuxha 6 11,835 12-12-2019, 04:43 AM
Last Post: dukla2000
