Unable to boot from SPI
(07-22-2018, 07:26 AM)tllim Wrote:
(06-29-2018, 06:16 AM)stevefan1999 Wrote: So I had flashed my SPI via SD card method, I waited until the LED goes blinking and turned off the device, and then I flashed my USB 3.0 drive to OMV with Etcher in Windows, and now it isn't booting at all! HDMI has no signal after I started the booting, neither was there any blinkings anymore, I have very limited hardware debugging skill and I simply want to know how to restore access to my Rock64, thank you.
If you thinks is cause by SPI Flash implementation, you can ease SPI Flash using below link:
http://wiki.pine64.org/index.php/NOOB#Er...riting_SPI
I'm having the same problem after using the U-boot erase program.  I also waited until the LED started a continuous blinking.  I then turned the machine off and now can't read from the SPI.  I had been using the USB for SSDs and µSD holders.  Now there is no response ... ability to read anything.  The Internet port also appears to be dead.  I have a number of good builds, but the won't boot.
Unable to boot from SPI - by stevefan1999 - 06-29-2018, 06:16 AM
RE: Unable to boot from SPI - by stevefan1999 - 06-29-2018, 06:38 AM
RE: Unable to boot from SPI - by stevefan1999 - 07-19-2018, 12:42 AM
RE: Unable to boot from SPI - by tllim - 07-22-2018, 07:26 AM
RE: Unable to boot from SPI - by rhens1 - 05-01-2019, 04:47 PM
  Rock64 won't boot luminosity7 10 4,056 03-16-2024, 08:33 AM
Last Post: dmitrymyadzelets
  Rock64 doesn't boot dstallmo 1 323 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 1,524 02-29-2024, 02:12 PM
Last Post: reukiodo
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,073 11-29-2022, 11:31 AM
Last Post: Macgyver
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,045 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  boot hdd usb3 philipe 1 2,638 01-27-2021, 02:12 PM
  Libreelec Rock64 - 4GB no boot spiker15 3 4,551 11-02-2020, 12:36 AM
Last Post: wilsonYan
  Rock64 - boot helpmerock 2 3,526 10-08-2020, 01:29 PM
Last Post: helpmerock
  No boot up after power on Whoopsadaisy 4 5,641 09-26-2020, 05:14 PM
Last Post: simonsouth
Bug u-boot (forks) status mcerveny 14 15,312 08-27-2020, 01:44 PM
Last Post: globaltree
