Resize /Boot mmcblk0p1 on SD?
Does anyone have a clean solution for how to increase the size of the /boot partition on a Ubuntu Mate SD based image?
Issue: I'm trying to install updates and the free 35M (out of 50M) volume is insufficient for the requested 150M of space that Updater wants.
I have plenty of room on my SD card. However, unless I'm mistaken, /boot must be contiguous. Since Gparted will only work on non-mounted volumes...
I'm running into issues with an Ubuntu VirtualBox image mounting my SD card via USB adapter. And the USB based live Ubuntu image is not happy booting with my video configuration. So, I'm being thwarted from being able to manipulate the partitions on an alternate Linux platform.
Also, does anyone know if mmcblk0p1 must be located in a specific offset on the SD card? If I have read correctly, Pint64 support MBR type partition tables and should be somewhat flexible?
Resize /Boot mmcblk0p1 on SD? - by chadc - 06-26-2018, 03:31 PM
RE: Resize /Boot mmcblk0p1 on SD? - by pfeerick - 06-26-2018, 03:52 PM
RE: Resize /Boot mmcblk0p1 on SD? - by chadc - 06-26-2018, 10:33 PM
RE: Resize /Boot mmcblk0p1 on SD? - by chadc - 06-27-2018, 06:07 PM
RE: Resize /Boot mmcblk0p1 on SD? - by tazthecat - 07-19-2018, 12:49 AM
RE: Resize /Boot mmcblk0p1 on SD? - by pfeerick - 06-27-2018, 10:01 PM
RE: Resize /Boot mmcblk0p1 on SD? - by chadc - 06-27-2018, 10:59 PM
RE: Resize /Boot mmcblk0p1 on SD? - by goathunter - 08-24-2018, 01:23 PM
  Pine 1 will no longer boot (bricked) dstallmo 0 1,291 06-22-2023, 12:22 PM
Last Post: dstallmo
  Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab pqueiro 0 3,052 06-10-2019, 12:07 PM
Last Post: pqueiro
  +LTS/SOPINE Compilation procedure for U-Boot and Linux for pineA64 LTS. danpurprakash@gmail.com 1 4,153 06-05-2019, 11:50 PM
Last Post: igorp
  Pine Board using linux stuck during boot sequence ktaragorn 0 2,805 03-23-2019, 04:06 AM
Last Post: ktaragorn
  Ubuntu boot very slow with wifi driver remainder 9 20,845 08-03-2017, 07:23 AM
Last Post: victorssantos
  Need help with boot options Gnx 1 3,409 01-22-2017, 09:27 PM
Last Post: MarkHaysHarris777
  straight boot into desktop Ola 2 3,828 08-01-2016, 11:12 PM
Last Post: Ola
  UBUNTU first boot Clouddead 6 7,125 06-29-2016, 12:40 PM
Last Post: pineacle
  in search for the /boot/config-...... file pelgrim 19 18,659 05-31-2016, 07:07 AM
Last Post: pelgrim
  Boot Ubuntu in CLI mode utdrmac 6 8,578 04-24-2016, 03:12 PM
Last Post: androsch
