Considering buying and question on the PCIe slot
(07-31-2018, 12:40 AM)joe2gaan Wrote:
(07-30-2018, 10:38 PM)MobileJAD Wrote:
(07-30-2018, 06:07 PM)joe2gaan Wrote:
(07-26-2018, 06:42 PM)Pniqolus Wrote:
(07-26-2018, 05:14 PM)Firesped Wrote: the PCIe slot is only x4 long. Most GPU are far longer. the only ones that would fit are PCIe x1. Alternatively you would need a m.2 adapter to PCIe x16 slot to fit a GPU.
Not to be rude, but this is not true. Yes, it is only PCIex4, but the slot on the ROCK64 is open-ended, so it can fit longer cards.
Plus there's also a plethora of pcie ribbon cables and slot adapters, if I were to build a system using the Rock Pro 64, I wouldn't necessarily cram a full size GTX 1080ti with a three slot wide gaming cooler on it, and crush the poor SBC underneath it. I could mount the GPU to the side of the SBC in a small pcie chassis like the ones those egpu kits use and run a pcie ribbon cable to the Rock Pro 64.
Right now I just want to know what the Rock Pro 64 would do if a Nvidia or AMD graphics card were plugged into its pcie slot.
Done!  Now to install some drivers. This was done in Arch Linux.
Can it output video to the video card? Without any displays hooked up to the SBC?
I am testing that now. I need to reconfigure my image.
[/quote]
Any luck?
I just purchased a Rockpro64 kit, I'm very curious what PCIe cards will work using drivers included with the Linux kernel and what devices will work but only after some extra work.
RE: Considering buying and question on the PCIe slot - by MobileJAD - 08-10-2018, 11:56 AM
Question Another Fan Question backwoodstech2 1 360 02-03-2024, 04:09 PM
Last Post: backwoodstech2
Information Question regarding odd startup behaviour Mff 0 1,182 12-03-2022, 03:18 PM
Last Post: Mff
  PCIE interface power on too late Slark Xiao 0 1,013 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  PCIe gen1 timeout - how to debug tosi 3 4,567 03-10-2022, 05:06 PM
Last Post: db579
  Anyone try an NVIDIA GPU in the PCIe slot? Paraplegic Racehorse 0 1,740 04-15-2021, 11:46 AM
Last Post: Paraplegic Racehorse
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 1,766 02-11-2021, 10:18 AM
Last Post: LMM
  PCIe Armbian and Ayufan for nvme ssd LMM 1 2,673 02-03-2021, 04:38 PM
Last Post: LMM
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 5,695 10-20-2020, 10:52 AM
Last Post: GreyLinux
  PCIe x4 mode - Lane 3 failure acdkyn 1 2,781 04-24-2020, 01:32 PM
Last Post: kuleszdl
  micro SD Card Slot Spring not working, Cant boot mjembd 1 3,127 04-16-2020, 12:30 AM
Last Post: mjembd
