Armbian for Rock64
(02-02-2020, 07:31 AM)dudemo Wrote:
(02-01-2020, 10:44 PM)janke Wrote:
(02-01-2020, 07:36 AM)dudemo Wrote:
(02-01-2020, 02:50 AM)clach04 Wrote:
(01-30-2020, 08:23 PM)janke Wrote: Hi pineadmin:
I have several questions to ask:
1. For rock64, how to distinguish V2 or V3?
2. How do I burn the armbian Linux image to EMMC? It seems that can't use Android tool.exe, right? No relevant information can be found everywhere. Please give me some advice!
For #1 are you asking how to look at a board and know what it is?
I have a ver 2 board and it states ver 2 in text on the top/front above the SoC. If you look at this https://store.pine64.org/?product=rock64...d-computer picture you can see this was says ver 1.
I have a version 1 board. Anything made for version 2 will work for version 1. I'm not so certain about version 3 on version 1.
If you buy a Rock64 new from Pine, your getting a version 3. If you bought one in the last year or so, probably a version 3.
Bought one in mid to late 2018, probably version 2.
Bought one in mid 2017 to early 2018, probably a version 1, possibly a version 2 if you bought it later than earlier.
Thanks your reply,but,i want to know:
It has been a long time since I ran Armbian but I'm pretty certain Armbian had a config that allows you to transfer a working SD boot to EMMC. This works if you do NOT have an EMMC to USB module.
Setup Armbian on SD with balenaEtcher. Insert it into your Rock64 and boot from SD card WITH the EMMC module plugged into the Rock64 as well. Run armbian-config. There's an option to transfer everything to EMMC. Your next boot will transfer, automatically reboot to EMMC, and boot from EMMC.
If you have an EMMC to USB adapter (Pine64 store sells one cheap!) then you can use balenaEtcher just as you would a SD card. Plug it into your Rock64 after balenaEtcher is done and boot. That's all.
Thanks again very much!
Now all I know about rock64 is from the forum and online search. Is there a complete document to learn about rock64? For example, I now use the sdcard to start the board. Diept can't detect EMMC. What should I do? There are many operating systems supported by rock64. For each system supporting EMMC, how to write the system to EMMC and where can I find it? For these problems, rock64 officials should provide relevant information. Thank you again for your support!
Armbian for Rock64 - by pineadmin - 06-19-2018, 02:35 AM
RE: Armbian for Rock64 - by pineadmin - 11-13-2018, 12:22 AM
RE: Armbian for Rock64 - by pineadmin - 05-31-2019, 01:59 AM
RE: Armbian for Rock64 - by pineadmin - 06-13-2019, 02:00 AM
RE: Armbian for Rock64 - by domih - 06-14-2019, 09:31 PM
RE: Armbian for Rock64 - by igorp - 07-07-2019, 03:57 AM
RE: Armbian for Rock64 - by tllim - 07-08-2019, 07:40 PM
RE: Armbian for Rock64 - by pineadmin - 07-08-2019, 07:51 PM
RE: Armbian for Rock64 - by pineadmin - 08-05-2019, 12:57 AM
RE: Armbian for Rock64 - by janke - 01-30-2020, 08:23 PM
RE: Armbian for Rock64 - by clach04 - 02-01-2020, 02:50 AM
RE: Armbian for Rock64 - by dudemo - 02-01-2020, 07:36 AM
RE: Armbian for Rock64 - by janke - 02-01-2020, 10:44 PM
RE: Armbian for Rock64 - by dudemo - 02-02-2020, 07:31 AM
RE: Armbian for Rock64 - by janke - 02-03-2020, 01:45 AM
RE: Armbian for Rock64 - by janke - 02-01-2020, 10:40 PM
RE: Armbian for Rock64 - by martinayotte - 02-02-2020, 09:23 AM
RE: Armbian for Rock64 - by tomarm - 02-02-2020, 09:13 PM
RE: Armbian for Rock64 - by dudemo - 02-03-2020, 11:12 AM
RE: Armbian for Rock64 - by janke - 02-03-2020, 11:07 PM
RE: Armbian for Rock64 - by kapqa - 03-26-2020, 03:13 AM
RE: Armbian for Rock64 - by Enig123 - 03-28-2020, 01:07 PM
RE: Armbian for Rock64 - by tomarm - 04-03-2020, 05:38 PM
RE: Armbian for Rock64 - by fchazal - 04-20-2020, 05:51 AM
RE: Armbian for Rock64 - by Rar9 - 12-16-2020, 01:46 AM
RE: Armbian for Rock64 - by Rocklobster - 12-16-2020, 06:54 AM
RE: Armbian for Rock64 - by lanefu - 12-25-2020, 11:07 PM
RE: Armbian for Rock64 - by Wizzard - 05-07-2021, 02:38 AM
RE: Armbian for Rock64 - by clach04 - 05-07-2021, 07:37 AM
RE: Armbian for Rock64 - by Wizzard - 05-08-2021, 03:51 AM
RE: Armbian for Rock64 - by clach04 - 05-08-2021, 08:15 AM
RE: Armbian for Rock64 - by arle - 10-13-2021, 10:14 AM
RE: Armbian for Rock64 - by Wizzard - 05-08-2021, 09:35 AM
RE: Armbian for Rock64 - by Rocklobster - 10-16-2021, 01:40 PM
RE: Armbian for Rock64 - by Wizzard - 11-27-2021, 08:06 AM
RE: Armbian for Rock64 - by arle - 10-21-2021, 02:15 PM
RE: Armbian for Rock64 - by Rocklobster - 10-21-2021, 07:36 PM
RE: Armbian for Rock64 - by gedas07 - 01-18-2022, 12:57 PM
RE: Armbian for Rock64 - by Rocklobster - 01-20-2022, 08:12 PM
RE: Armbian for Rock64 - by gedas07 - 01-21-2022, 12:27 PM
RE: Armbian for Rock64 - by Rocklobster - 01-22-2022, 08:43 AM
RE: Armbian for Rock64 - by gedas07 - 01-23-2022, 06:20 AM
RE: Armbian for Rock64 - by Rocklobster - 01-24-2022, 05:55 AM
RE: Armbian for Rock64 - by gedas07 - 01-29-2022, 03:15 AM
RE: Armbian for Rock64 - by va88 - 02-08-2022, 08:23 PM
RE: Armbian for Rock64 - by Rocklobster - 02-10-2022, 08:54 PM
RE: Armbian for Rock64 - by gedas07 - 02-28-2022, 11:44 AM
RE: Armbian for Rock64 - by TRS-80 - 02-28-2022, 02:22 PM
RE: Armbian for Rock64 - by gedas07 - 03-01-2022, 03:59 PM
RE: Armbian for Rock64 - by TRS-80 - 03-02-2022, 07:27 PM
RE: Armbian for Rock64 - by Rocklobster - 03-02-2022, 09:08 PM
RE: Armbian for Rock64 - by spiritofjerry - 03-28-2022, 10:13 PM
RE: Armbian for Rock64 - by TRS-80 - 03-30-2022, 07:18 PM
RE: Armbian for Rock64 - by TRS-80 - 03-31-2022, 12:11 PM
RE: Armbian for Rock64 - by spiritofjerry - 03-31-2022, 03:30 PM
RE: Armbian for Rock64 - by Rocklobster - 03-31-2022, 05:24 PM
RE: Armbian for Rock64 - by spiritofjerry - 03-31-2022, 05:26 PM
RE: Armbian for Rock64 - by TRS-80 - 04-01-2022, 03:16 PM
  Xen hypervisor on Rock64 tumbleweed 6 9,684 Yesterday, 09:25 AM
Last Post: darkfader
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 9 15,792 07-20-2025, 01:00 PM
  Rock64 - not booting after Armbian update helpmerock 6 3,656 03-27-2025, 08:26 AM
  can rock64 4gb ram run entirely on free software? heocb 1 2,359 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,487 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,516 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 68,601 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 100,220 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 4,437 03-14-2024, 03:09 AM
  Rock64 won't boot dstallmo 0 2,608 12-27-2023, 10:34 AM
Last Post: dstallmo
