Armbian for Rock64
#51
(03-02-2022, 07:27 PM)TRS-80 Wrote:
(03-01-2022, 03:59 PM)gedas07 Wrote: Where I can find the image ?
OK, in general:
https://www.armbian.com/download/
But you will notice it's not listed.  You can still manually go to https://www.armbian.com/rock64/ however, but here we must note a few very important things:
  • It's CSC (no support).  This is a red flag.
  • There is a link to a forum thread about stability.
  • There is another note about eMMC troubles.
At this point I am wondering which image Rocklobster is using?  Did you build?  Because I see a lot of red flags here.
Are you sure Rocklobster you are referring to Rock64 (and not ROCKPro64)?  I just want to be sure.
(03-01-2022, 03:59 PM)gedas07 Wrote: Is it possible to install it without losing anything already installed?
Generally speaking, this is not supported.  However there are some people on the forums telling how to do this.  You would be on your own however.
But there seem to be much bigger problems here, proceed with caution!
I knew this sounded vaguely familiar.  I see gedas07 that you found your way to make this post.  I would advise to keep looking around the forums there and see if anyone found a solution.  Otherwise we are into development and bug fixing here.
Armbian 21.5.04 Buster Linux 5.10,63 Rockchip64 and this Is definitely for the Rock64 board. I generally start from a fresh install when upgrading between releases. I've never had much luck upgrading on Linux OS in situ.
Armbian for Rock64 - by pineadmin - 06-19-2018, 02:35 AM
RE: Armbian for Rock64 - by pineadmin - 11-13-2018, 12:22 AM
RE: Armbian for Rock64 - by pineadmin - 05-31-2019, 01:59 AM
RE: Armbian for Rock64 - by pineadmin - 06-13-2019, 02:00 AM
RE: Armbian for Rock64 - by domih - 06-14-2019, 09:31 PM
RE: Armbian for Rock64 - by igorp - 07-07-2019, 03:57 AM
RE: Armbian for Rock64 - by tllim - 07-08-2019, 07:40 PM
RE: Armbian for Rock64 - by pineadmin - 07-08-2019, 07:51 PM
RE: Armbian for Rock64 - by pineadmin - 08-05-2019, 12:57 AM
RE: Armbian for Rock64 - by janke - 01-30-2020, 08:23 PM
RE: Armbian for Rock64 - by clach04 - 02-01-2020, 02:50 AM
RE: Armbian for Rock64 - by dudemo - 02-01-2020, 07:36 AM
RE: Armbian for Rock64 - by janke - 02-01-2020, 10:44 PM
RE: Armbian for Rock64 - by dudemo - 02-02-2020, 07:31 AM
RE: Armbian for Rock64 - by janke - 02-03-2020, 01:45 AM
RE: Armbian for Rock64 - by janke - 02-01-2020, 10:40 PM
RE: Armbian for Rock64 - by martinayotte - 02-02-2020, 09:23 AM
RE: Armbian for Rock64 - by tomarm - 02-02-2020, 09:13 PM
RE: Armbian for Rock64 - by dudemo - 02-03-2020, 11:12 AM
RE: Armbian for Rock64 - by janke - 02-03-2020, 11:07 PM
RE: Armbian for Rock64 - by kapqa - 03-26-2020, 03:13 AM
RE: Armbian for Rock64 - by Enig123 - 03-28-2020, 01:07 PM
RE: Armbian for Rock64 - by tomarm - 04-03-2020, 05:38 PM
RE: Armbian for Rock64 - by fchazal - 04-20-2020, 05:51 AM
RE: Armbian for Rock64 - by Rar9 - 12-16-2020, 01:46 AM
RE: Armbian for Rock64 - by Rocklobster - 12-16-2020, 06:54 AM
RE: Armbian for Rock64 - by lanefu - 12-25-2020, 11:07 PM
RE: Armbian for Rock64 - by Wizzard - 05-07-2021, 02:38 AM
RE: Armbian for Rock64 - by clach04 - 05-07-2021, 07:37 AM
RE: Armbian for Rock64 - by Wizzard - 05-08-2021, 03:51 AM
RE: Armbian for Rock64 - by clach04 - 05-08-2021, 08:15 AM
RE: Armbian for Rock64 - by arle - 10-13-2021, 10:14 AM
RE: Armbian for Rock64 - by Wizzard - 05-08-2021, 09:35 AM
RE: Armbian for Rock64 - by Rocklobster - 10-16-2021, 01:40 PM
RE: Armbian for Rock64 - by Wizzard - 11-27-2021, 08:06 AM
RE: Armbian for Rock64 - by arle - 10-21-2021, 02:15 PM
RE: Armbian for Rock64 - by Rocklobster - 10-21-2021, 07:36 PM
RE: Armbian for Rock64 - by gedas07 - 01-18-2022, 12:57 PM
RE: Armbian for Rock64 - by Rocklobster - 01-20-2022, 08:12 PM
RE: Armbian for Rock64 - by gedas07 - 01-21-2022, 12:27 PM
RE: Armbian for Rock64 - by Rocklobster - 01-22-2022, 08:43 AM
RE: Armbian for Rock64 - by gedas07 - 01-23-2022, 06:20 AM
RE: Armbian for Rock64 - by Rocklobster - 01-24-2022, 05:55 AM
RE: Armbian for Rock64 - by gedas07 - 01-29-2022, 03:15 AM
RE: Armbian for Rock64 - by va88 - 02-08-2022, 08:23 PM
RE: Armbian for Rock64 - by Rocklobster - 02-10-2022, 08:54 PM
RE: Armbian for Rock64 - by gedas07 - 02-28-2022, 11:44 AM
RE: Armbian for Rock64 - by TRS-80 - 02-28-2022, 02:22 PM
RE: Armbian for Rock64 - by gedas07 - 03-01-2022, 03:59 PM
RE: Armbian for Rock64 - by TRS-80 - 03-02-2022, 07:27 PM
RE: Armbian for Rock64 - by Rocklobster - 03-02-2022, 09:08 PM
RE: Armbian for Rock64 - by spiritofjerry - 03-28-2022, 10:13 PM
RE: Armbian for Rock64 - by TRS-80 - 03-30-2022, 07:18 PM
RE: Armbian for Rock64 - by TRS-80 - 03-31-2022, 12:11 PM
RE: Armbian for Rock64 - by spiritofjerry - 03-31-2022, 03:30 PM
RE: Armbian for Rock64 - by Rocklobster - 03-31-2022, 05:24 PM
RE: Armbian for Rock64 - by spiritofjerry - 03-31-2022, 05:26 PM
RE: Armbian for Rock64 - by TRS-80 - 04-01-2022, 03:16 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 17,429 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 585 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 5,013 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 10,968 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 2,813 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,924 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,109 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 80,890 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 106,104 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 5,479 03-14-2024, 03:09 AM
