Rock64 no longer boots after dist-upgrade
You are right, forgot the efi parition
Something weird seems to be going on with the one that's mounted by default (or I just don't understand
rock64@rock64:/mnt/efimmc$ df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            2.0G     0  2.0G   0% /dev
tmpfs           393M  5.4M  388M   2% /run
/dev/mmcblk1p7   15G  1.6G   13G  12% /
tmpfs           2.0G     0  2.0G   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           2.0G     0  2.0G   0% /sys/fs/cgroup
/dev/mmcblk0p6  100M   50M   51M  50% /boot/efi
tmpfs           393M     0  393M   0% /run/user/1000
/dev/mmcblk0p7   29G  9.3G   18G  35% /mnt/bootmmc
/dev/mmcblk1p6  100M   24M   77M  24% /mnt/efimmc
The following two especially:
mmcblk1 = sdcard
mmcblk0 = emmc
So am I right in saying it mounts the wrong efi by default?
I didn't notice at first and mounted what I thought was the emmc to my own mount point (/mnt/efimmc) but ended up copying the same files back and forth  Tongue
After still not being able to boot I noticed, rebooted, remounted the sdcard efi to /boot/efi and mmc to /mnt/efimmc copied and BAM we're back in action!
Thanks a lot for pointing me in the right direction!
Could it be that copying the /boot/ and /boot/efi messed something up with my build?
Everything is working as before except for openvpn which can't initiate a connection anymore
ERROR: Cannot open TUN/TAP dev /dev/net/tun: No such file or directory (errno=2)
I checked, and indeed there is no /dev/net folder
RE: Rock64 no longer boots after dist-upgrade - by KernelPanic - 06-16-2018, 06:12 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 139 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,347 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 331 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 605 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 603 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,340 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,181 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 586 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 644 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,251 12-07-2022, 08:22 PM
Last Post: luminosity7
