Cluster Rack
Unfortunately, not yet.
I currently have 5 Rock64 so I have bought 3 of the BB02B blades and the chassis. I have been running the BB02B of a regular powerbrick because....
The chassis I got from Farnell in the UK http://uk.farnell.com/camdenboss/cbbrack...t=bitscope and it literally is just the case, a quite overpriced one at that.
A vital component was missing and it isn't available at Farnell apparently for a few months and that is the "cluster plate", see image, these are the things you actually attache the blades to within the case. I've had to contact Bitscope in AU and they are supplying them from there. They come in pairs and you need two pairs to populate the whole box. They are $75 each. I'm still waiting on this to be invoiced so I'm not sure whether it is Australian $, I hope so. Did I mention that this is not cheap? Smile
[Image: clusterplate.jpg]
If you don't want the full rack you can go with the smaller devices and run them off a power brick.
There is the BB02 and the BB04, there is also one with a bay for a Pi Hat:
[Image: bitscope.jpg]
I'm not sure about the BB04 though as it will only deliver 4 amps across all 4 devices.
They come with sticky plastic feet that can then be used to wall mount too:
[Image: 46-FB26H.jpg]
Cluster Rack - by digitaldaz - 06-14-2018, 02:20 AM
RE: Cluster Rack - by Luke - 06-14-2018, 03:02 AM
RE: Cluster Rack - by digitaldaz - 06-14-2018, 04:20 AM
RE: Cluster Rack - by Luke - 06-14-2018, 04:49 AM
RE: Cluster Rack - by digitaldaz - 06-14-2018, 04:52 AM
RE: Cluster Rack - by Luke - 06-14-2018, 04:55 AM
RE: Cluster Rack - by tllim - 06-20-2018, 04:18 PM
  Looking for advice on power supply for a rack of 4+ Rock64's fwo19 4 8,218 02-10-2018, 04:23 AM
Last Post: Gary_Cole
