rock64/ubuntu start-up
I advanced a little...
The red led that is on is the one near the white.
For my french keyboard, by changing the field XKBLAYOUT to "fr" in the file /etc/default/keyboard solve the problem. Like this it's more easy Smile
Then using apt command, i updated+upgraded what could be upgraded.
For the detection of usb devices, "File manager PCManFM" does not mount automatically (or not) these device although its preferences are set int this way. If i use the command line
sudo mount /dev/sda1 /media/usb
then the usb key contents is visible in the open file dialog of the softwares, but very seldom in PCManFM.
And, if i select Devices or Network in PCManFM, it gives the error: Operation not supported , which is in my mind different than an execution error.
Concerning the wifi, my wifi dongle is detected, but as i did not find a way to use it, i installed the package "network-manager-gnome". After that i have a icon in the taskbar but the icon has a little red cross over it. A clic on it, shows a menu in wich there is an item corresponding to my wifibox. But selecting this item do nothing; if i select the 'Edit connections...' item, a window is open showing my wifi box, but once again trying to edit these connections do nothing. Well,  probably it is necessary to install another packages, but which?
Any ideas?
Otherwise, as LXDE is a light DE, is it possible to install other DE package like gnome or KDE?
Apart these inconveniences, the board works better than with xenial-mate-rock64-0.5.15-136-arm64 (faster, more reliable).
regards
rock64/ubuntu start-up - by pas059 - 06-13-2018, 09:02 AM
RE: rock64/ubuntu stat-up - by Luke - 06-13-2018, 09:14 AM
RE: rock64/ubuntu stat-up - by pas059 - 06-13-2018, 10:41 AM
RE: rock64/ubuntu stat-up - by Luke - 06-13-2018, 01:27 PM
RE: rock64/ubuntu stat-up - by pas059 - 06-14-2018, 09:12 AM
RE: rock64/ubuntu stat-up - by pfeerick - 06-14-2018, 07:11 PM
RE: rock64/ubuntu stat-up - by Luke - 06-14-2018, 10:42 AM
RE: rock64/ubuntu stat-up - by pas059 - 06-14-2018, 12:00 PM
RE: rock64/ubuntu stat-up - by fire219 - 06-14-2018, 01:20 PM
RE: rock64/ubuntu stat-up - by pas059 - 06-15-2018, 12:26 PM
RE: rock64/ubuntu stat-up - by fire219 - 06-15-2018, 12:56 PM
RE: rock64/ubuntu stat-up - by pfeerick - 06-16-2018, 04:41 AM
RE: rock64/ubuntu stat-up - by pas059 - 06-16-2018, 10:10 AM
RE: rock64/ubuntu stat-up - by pfeerick - 06-16-2018, 04:15 PM
RE: rock64/ubuntu stat-up - by evilbunny - 06-16-2018, 05:05 PM
RE: rock64/ubuntu stat-up - by pfeerick - 06-16-2018, 05:18 PM
RE: rock64/ubuntu stat-up - by zet_lab - 06-16-2018, 11:58 PM
RE: rock64/ubuntu start-up - by pfeerick - 06-17-2018, 01:25 AM
RE: rock64/ubuntu start-up - by zet_lab - 06-17-2018, 11:58 AM
RE: rock64/ubuntu start-up - by pas059 - 06-18-2018, 11:56 AM
RE: rock64/ubuntu start-up - by fire219 - 06-18-2018, 09:04 PM
RE: rock64/ubuntu start-up - by pas059 - 06-19-2018, 02:29 AM
RE: rock64/ubuntu start-up - by pas059 - 06-21-2018, 09:45 AM
RE: rock64/ubuntu start-up - by fire219 - 06-21-2018, 11:25 AM
RE: rock64/ubuntu start-up - by pas059 - 06-21-2018, 11:57 AM
RE: rock64/ubuntu start-up - by pfeerick - 06-21-2018, 05:59 PM
RE: rock64/ubuntu start-up - by pas059 - 06-26-2018, 02:33 AM
RE: rock64/ubuntu start-up - by fire219 - 06-26-2018, 09:48 AM
RE: rock64/ubuntu start-up - by pas059 - 06-27-2018, 04:07 AM
RE: rock64/ubuntu start-up - by fire219 - 06-27-2018, 09:13 AM
RE: rock64/ubuntu start-up - by MrPosull - 06-27-2018, 11:44 AM
RE: rock64/ubuntu start-up - by pas059 - 06-27-2018, 12:36 PM
RE: rock64/ubuntu start-up - by fire219 - 06-27-2018, 01:00 PM
RE: rock64/ubuntu start-up - by pas059 - 06-28-2018, 03:42 AM
RE: rock64/ubuntu start-up - by pfeerick - 06-28-2018, 04:00 AM
RE: rock64/ubuntu start-up - by pas059 - 06-28-2018, 07:28 AM
RE: rock64/ubuntu start-up - by pas059 - 06-28-2018, 08:43 AM
  DietPi OS for ROCK64 MichaIng 41 17,526 12-07-2022, 08:22 PM
Last Post: luminosity7
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 126 132,483 11-13-2022, 01:04 PM
  Using multiple UART's on Rock64. ramprasad 0 267 08-29-2022, 01:22 PM
Last Post: ramprasad
  Using multiple UART's on Rock64. sachineswar 0 234 08-29-2022, 12:31 PM
Last Post: sachineswar
  Rock64 v2 - did not work song / audio sqw200zu 1 402 07-29-2022, 12:08 PM
Last Post: sqw200zu
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 5,196 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 423 06-27-2022, 06:52 PM
  Armbian for Rock64 pineadmin 57 51,855 04-01-2022, 03:16 PM
Last Post: TRS-80
  Fedora 35 on rock64 dafsjr 4 1,957 03-19-2022, 10:03 PM
Last Post: t4_4t
  openwrt for the rock64 wilsonYan 29 17,948 03-13-2022, 10:25 PM
Last Post: CanadianBacon
