Raspberry Pi OneNineDesign Case "Mod"
I've bought a quite cheap (2.36 €) version of this case on aliexpress for tinkering, don't know if it's a copy or not, case looks very good and nicely polished.
In order to put a Rock64 into it, some "adjustments" were needed, mostly for the board to fit inside, but also for power and A/V jack which are weirdly shifted a bit on the right when you put the board in front of you.
here [click to show the album] are some pics of the "rough surgery" the case got.
There are still some work to do to get access to switches near the recovery one and make a hole for the IR receiver just in case.
I first use pliers to remove the big plastic part inside, then a modelling knife and a grinding tool to got a smooth finish.
(If you have any trouble accessing the album, please let me know, I upload pics on imgBB and set the permission in order anyone clicking on the link can show it)
Raspberry Pi OneNineDesign Case "Mod" - by MichaelRock - 06-04-2018, 05:15 AM
  DeskPi case alternative for ROCK64 v1k699 2 11,682 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 3,519 05-13-2025, 07:32 AM
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 7,876 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
Smile wooden case for ROCK64 killor 13 25,174 03-04-2022, 06:56 AM
Last Post: killor
  Assembling the premium aluminum case mlefevre 14 24,506 07-07-2021, 05:50 AM
Last Post: Rocklobster
Heart Best quick/easy way to control case fan speed? idillicah 4 10,525 06-24-2021, 09:14 AM
Last Post: CounterPillow
  What thermal compound will fit better to the aluminum case? m.bakhterev 1 4,353 01-26-2020, 12:56 PM
Last Post: clach04
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 22,531 07-09-2019, 06:15 AM
Last Post: merwone
  Rock64's temperature while being in aluminium case _zernok 3 8,570 06-23-2019, 08:00 AM
Last Post: rasputin
  Fitting Rockpro64 inside Pinebook case made2hack 2 5,853 02-20-2019, 01:27 AM
Last Post: made2hack
