boot logs shows chinese ip trying to login ssh
(06-01-2018, 08:25 AM)Rocklobster Wrote: Have you any periphals like cameras attached. They're notorious for calling back home. You did a reverse lookup so you know the source. Hackers haven.
This true in Windows where cheap no-name imported devices often require installation of unsigned suspect drivers.   It should NOT happen in Linux with vetted opensource drivers.
But your observation that this may have happened because the Rock64 "phoned home" is probably right on track, because in my experience, most of the time, an attack like this is not due to random port scanning, but is rather a targeted attempt to compromise a machine where some kind of embeded malware has pinged back to the mothership.
If the original poster had been foolish enough to have not reset the root password BEFORE connecting to the internet (as many are) then the Rock64 would have immediately been compromised and become a vector to attempt to compromise EVERY OTHER MACHINE ON THE LOCAL NETWORK.
This is serious stuff.  Someone should setup up a dummy honeypot network with some old PC's with names like DARPA_370 and LAB_04, then hook a fresh Rock64 up through a logging router or access point and see if it starts to sniff around and then tries to "phone home".
RE: boot logs shows chinese ip trying to login ssh - by Z80 - 06-02-2018, 07:25 PM
  Rock64 won't boot luminosity7 10 4,144 03-16-2024, 08:33 AM
Last Post: dmitrymyadzelets
  Rock64 doesn't boot dstallmo 1 334 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 1,533 02-29-2024, 02:12 PM
Last Post: reukiodo
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,103 11-29-2022, 11:31 AM
Last Post: Macgyver
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,060 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  boot hdd usb3 philipe 1 2,651 01-27-2021, 02:12 PM
  Libreelec Rock64 - 4GB no boot spiker15 3 4,570 11-02-2020, 12:36 AM
Last Post: wilsonYan
  Rock64 - boot helpmerock 2 3,542 10-08-2020, 01:29 PM
Last Post: helpmerock
  No boot up after power on Whoopsadaisy 4 5,656 09-26-2020, 05:14 PM
Last Post: simonsouth
Bug u-boot (forks) status mcerveny 14 15,374 08-27-2020, 01:44 PM
Last Post: globaltree
