[Archived] Initial Linux release from ayufan (0.6.XX)
I am having problems with ayufan's distros from  git hub. trying to write the sd card with my Linux Mint system, which has always written  successfully hundreds of times in the past.
1. Git hub appears crippled, keeps dropping d/l transfer, I installed a Linux file downloader and have to keep restarting, but still takes forever to get a complete download.
2. After writing  bionic minimal .img to a fresh fat32 formatted SD card , I can mount the boot partition on my Linux Mint pc, and look at the files, HOWEVER the root-fs partition is formatted to ext4, and for some reason will not mount.
If look at the card with gparted it looks like the partitioning is most unusual, if not incorrect.
I see 5  unknown partitions about 3-4 MiB in length, The first unknown is at block 64.
then partition 6 the Boot partition, fat16, 112Mib, starting at 32768
partition 7 is the linux-root partion formatted to ext4 2GiB in size starting at 262144
I have tried a dozen good sd cards and linux dd, etcher and Mint usb stick writer, all of which normally work
When trying to boot the rockpro board, I see a second or so of leds flashing in the ethernet connector but nothing else happens.
I have tried  bionic minimal and bionic lxde, same problem  DEFINITELY writing the distro for the rockpro!
any advice gratefully received
Patrick
Problems with Initial Linux release from ayufan (0.6.XX) - by superpat - 06-01-2018, 05:48 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 9 16,598 10-31-2025, 06:33 PM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 3,935 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 5,451 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 6,667 04-23-2023, 01:32 PM
Last Post: diederik
  Linux laptop does not detect the board when plugged in via USB soupy 1 6,171 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 linux console video mode callegar 0 2,060 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 14,263 04-30-2022, 03:57 PM
Last Post: TRS-80
  Armbian 22.02 Release Announcement TRS-80 0 2,224 02-28-2022, 05:08 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 8,227 01-03-2022, 10:32 AM
Last Post: whitecat23
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 2,543 07-24-2021, 09:46 PM
Last Post: Mentaluproar
