Is PCIE x4 bootable for NVMe SSD under Linux
#26
Tried rootdelay=20, did not help. Also tried timeout 200 which was equally futile.
I have zero knowledge on what causes what to happen during boot but clearly 4.4 gets the nvme ready very early in the process, and 4.18 does not. See the 2 logs below.
$uname -a
Linux rockpro64 4.4.132-1075-rockchip-ayufan-ga83beded8524 #1 SMP Thu Jul 26 08:22:22 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
$dmesg | grep nvme
[    3.366224] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[    3.509043]  nvme0n1: p1
$dmesg | grep pcie
[    0.504048] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-pcie-regulator[0]' - status (0)
[    0.504098] reg-fixed-voltage vcc3v3-pcie-regulator: Looking up vin-supply from device tree
[    0.504137] vcc3v3_pcie: supplied by dc_12v
[    0.504203] vcc3v3_pcie: 3300 mV
[    0.504358] reg-fixed-voltage vcc3v3-pcie-regulator: vcc3v3_pcie supplying 3300000uV
[    2.774636] vcc3v3_pcie: disabling
[    3.078824] phy phy-pcie-phy.9: Looking up phy-supply from device tree
[    3.078828] phy phy-pcie-phy.9: Looking up phy-supply property in node /pcie-phy failed
[    3.142089] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[    3.142103] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[    3.142163] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[    3.142496] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[    3.142741] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[    3.142753] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[    3.142786] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    3.150011] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[    3.150027] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[    3.150057] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    3.157191] rockchip-pcie f8000000.pcie: invalid power supply
[    3.229681] PCI host bridge /pcie@f8000000 ranges:
[    3.259602] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    3.344039] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    3.351408] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    3.365337] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[    3.365681] aer 0000:00:00.0:pcie02: service driver aer loaded
$dmesg | grep EXT4-fs
[    4.022277] EXT4-fs (mmcblk0p7): mounted filesystem with writeback data mode. Opts: (null)
At 4.4 the pcie & nvme initialisation is ready before the rootfs is mounted (even though I am booting off the SDcard).
$uname -a
Linux rockpro64 4.18.0-rc8-1060-ayufan-g45828c4db727 #1 SMP PREEMPT Thu Aug 9 19:41:21 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
$dmesg ? grepp nvme
[   11.267625] nvme nvme0: pci function 0000:01:00.0
[   11.267700] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[   11.403278]  nvme0n1: p1
$dmesg | grep pcie
[    1.772645] vcc3v3_pcie: supplied by dc_12v
[    3.557384] vcc3v3_pcie: disabling
[   11.190914] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[   11.190998] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[   11.191009] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[   11.258608] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[   11.258634] rockchip-pcie f8000000.pcie:   MEM 0xfa000000..0xfbdfffff -> 0xfa000000
[   11.258642] rockchip-pcie f8000000.pcie:    IO 0xfbe00000..0xfbefffff -> 0xfbe00000
[   11.258909] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    4.534168] EXT4-fs (mmcblk0p7): mounted filesystem with writeback data mode. Opts: (null)
At 4.18 the pcie & nvme initialisation only happens way after the rootfs is mounted.
(08-11-2018, 06:49 AM)Tigger Wrote: What exactly is on the eMMC ?
Is a bionic minimal image - / on p7 etc. This is a separate issue I have with 4.18: if the emmc is plugged in when booting then the 4.18 kernel fails to complete its boot as it appears to be not able to initialise the emmc, and gets into infinite loop
mmc1: running CQE recovery
repeating this every 60s
RE: Is PCIE x4 bootable for NVMe SSD under Linux - by dukla2000 - 08-12-2018, 03:52 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 569 03-25-2024, 12:12 PM
  RK3399 PCIe enumeration jhadd 0 298 01-31-2024, 08:56 AM
Last Post: jhadd
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 877 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,363 07-14-2023, 04:22 AM
Last Post: hunderteins
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,049 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 2,257 10-14-2022, 06:24 AM
Last Post: rwk-
  RockPro64 linux console video mode callegar 0 900 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 8,342 04-30-2022, 03:57 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 4,374 01-03-2022, 10:32 AM
Last Post: whitecat23
  No PCIe controller detected... Limhes 1 1,621 11-23-2021, 06:23 AM
Last Post: Limhes
