Is PCIE x4 bootable for NVMe SSD under Linux
(08-03-2018, 08:39 AM)Bullet64 Wrote: @jzhang: It's possible, with a little problem - only cold start Sad No reset button, no 'shutdown -r now' atm.
https://forum.frank-mankel.org/topic/208...vme-platte Sorry, only german, but i think it's easy to understand.
I saw you modified eMMC (or microSD) /boot/extlinux/extlinux.conf
After you switch "/" to NVMe SSD,   you should do it again to modify: /boot/extlinux/extlinux.conf
So both your eMMC and NVMe SSD point to NVMe SSD  as "/"
Then 'shutdown -r now', 'reboot', reset button -- might work consistently as "cold start" I guess.
RE: Is PCIE x4 bootable for NVMe SSD under Linux - by jzhang18 - 08-03-2018, 02:14 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 523 03-25-2024, 12:12 PM
  RK3399 PCIe enumeration jhadd 0 287 01-31-2024, 08:56 AM
Last Post: jhadd
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 859 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,340 07-14-2023, 04:22 AM
Last Post: hunderteins
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,033 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 2,243 10-14-2022, 06:24 AM
Last Post: rwk-
  RockPro64 linux console video mode callegar 0 892 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 8,292 04-30-2022, 03:57 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 4,334 01-03-2022, 10:32 AM
Last Post: whitecat23
  No PCIe controller detected... Limhes 1 1,606 11-23-2021, 06:23 AM
Last Post: Limhes
