05-17-2018, 11:24 AM
(This post was last modified: 05-17-2018, 01:13 PM by wirr.
Edit Reason: fix typo
Hi all, I'm looking for help with tftp boot from SPI flash.
Booting from flash works fine, the rock boards load their pxelinux.0 from tftp. Then for some reason the bootloader seems to ignore my 'fdt /dtb' entry and requests /dtb/rockchip/rk3328-rock64.dtb.
After successfully loading this file it throws the following error:
Filename 'dtb/rockchip/rk3328-rock64.dtb'.
Load address: 0x1f00000
Loading: ####
1.8 MiB/s
done
Bytes transferred = 56922 (de5a hex)
## Starting EFI application at 02000000 ...
efi_load_pe: Invalid DOS Signature
## Application terminated, r = 9223372036854775806
Can someone provide any insight on why this happens and how to fix it?
Thanks!
For the sake of completeness here's my pxelinux.0:
default rock64-kernel-4.4
prompt 0
timeout 3
menu title Boot options
label rock64-kernel-4.4
kernel /Image
initrd /initrd.img
fdt /dtb
append earlycon=uart8250,mmio32,0xff130000 rw root=/dev/nfs nfsroot=${serverip}:/data/rootfs/rock64-1 rootwait init=/sbin/init mtdparts=spi32766.0:32k(system),4064k(loader),3840k(reserved),256k(vendor),4M(uboot),4M(atf)
Loading: ####
1.8 MiB/s
done
Thanks!
prompt 0
timeout 3
kernel /Image
initrd /initrd.img
fdt /dtb
