unable to switch usb3 ports on
(05-15-2018, 07:20 PM)t4_4t Wrote: The power supply of three usb-ports (usb-2.0 x 2, usb-3.0 x 1)
is controlled by the same control signal, it is not designed to be individually controllable.
And its control signal is GPIO-2.
If you are controlling the power(V-BUS) of usb-2.0 with the script you presented here
The power(V-BUS) supply of usb-3.0 should also be controlled at the same time.
However, the above answers will not solve your problem.
Because you already have control over the power of usb-3.0 .
What image was used
What is the problem in doing so
I think that it is better to present your problem more concretely.
Hi t4_4t,
thanks for your reply. I'm running a arch linux installation from https://archlinuxarm.org as a headless mail server. For backup reasons I would like to use the usb ports. With the script I mentioned, I managed to activate the usb2.0 ports, but the usb3.0 port has still no power.
Are you quite sure, that both are handled via the same gpio? With the Android image both ports are functioning quite well, so there's no hardware fault.
Best regards,
Christoph
unable to switch usb3 ports on - by cglhu - 05-14-2018, 12:15 PM
RE: unable to switch usb3 ports on - by tllim - 05-14-2018, 11:20 PM
RE: unable to switch usb3 ports on - by cglhu - 05-15-2018, 07:58 AM
RE: unable to switch usb3 ports on - by t4_4t - 05-15-2018, 07:20 PM
RE: unable to switch usb3 ports on - by cglhu - 05-16-2018, 11:26 AM
RE: unable to switch usb3 ports on - by pfeerick - 05-17-2018, 02:25 AM
RE: unable to switch usb3 ports on - by cglhu - 05-17-2018, 08:43 AM
  USB3 SATA ReleaseTheGeese 2 4,226 04-04-2021, 12:55 PM
Last Post: ReleaseTheGeese
  USB3 to SATA cable - Firmware Eule 0 2,974 03-03-2020, 01:31 PM
Last Post: Eule
  USB3 enough to power 2,5 external HDD? va88 11 19,825 06-06-2019, 03:40 PM
Last Post: va88
  Damaged / poorly-soldered ports? kasane 0 2,409 05-15-2019, 11:14 AM
Last Post: kasane
  are the usb ports on rock64 on separate bus? shome 1 4,152 09-22-2018, 01:29 AM
Last Post: evilbunny
  Best USB3.0 to SATA bridge mikedhoore 6 20,803 10-02-2017, 07:52 AM
Last Post: mikedhoore
