unable to switch usb3 ports on
(05-14-2018, 12:15 PM)cglhu Wrote: Hi all,
I have a problem with the usb3 ports. I run an arch linux installation on a rock64. I followed the instructions in this thread
https://forum.pine64.org/showthread.php?tid=5001
and that helped me to get usb2 ports working. But I can't do the same thing for the usb3 ports (toggle the right gpio to switch the regulator for usb3 on). Mostly I don't know, which gpio port belongs to the usb3 regulator.
Maybe someone can give me a hint.
Thanks in advance and
Best regards,
Christoph
ROCK64 schematic page 15.
http://files.pine64.org/doc/rock64/ROCK6...171019.pdf
unable to switch usb3 ports on - by cglhu - 05-14-2018, 12:15 PM
RE: unable to switch usb3 ports on - by tllim - 05-14-2018, 11:20 PM
RE: unable to switch usb3 ports on - by cglhu - 05-15-2018, 07:58 AM
RE: unable to switch usb3 ports on - by t4_4t - 05-15-2018, 07:20 PM
RE: unable to switch usb3 ports on - by cglhu - 05-16-2018, 11:26 AM
RE: unable to switch usb3 ports on - by pfeerick - 05-17-2018, 02:25 AM
RE: unable to switch usb3 ports on - by cglhu - 05-17-2018, 08:43 AM
  USB3 SATA ReleaseTheGeese 2 4,226 04-04-2021, 12:55 PM
Last Post: ReleaseTheGeese
  USB3 to SATA cable - Firmware Eule 0 2,974 03-03-2020, 01:31 PM
Last Post: Eule
  USB3 enough to power 2,5 external HDD? va88 11 19,825 06-06-2019, 03:40 PM
Last Post: va88
  Damaged / poorly-soldered ports? kasane 0 2,409 05-15-2019, 11:14 AM
Last Post: kasane
  are the usb ports on rock64 on separate bus? shome 1 4,152 09-22-2018, 01:29 AM
Last Post: evilbunny
  Best USB3.0 to SATA bridge mikedhoore 6 20,803 10-02-2017, 07:52 AM
Last Post: mikedhoore
