can a SD card be used as storage with emmc boot
(05-03-2018, 06:24 AM)Enzo Wrote: keep getting:
enzo@rock64:~/Desktop$ sudo mount /dev/mmcblk1 /mnt/SD
mount: /dev/mmcblk1: can't read superblock
That error is correct, as you are trying to mount the entire SD card, rather than the partition. The command you use later should work, if your SD card's first partition is readable, and that the directory /mnt/SD exists (else you'll get a different error again).
(05-03-2018, 06:24 AM)Enzo Wrote: enzo@rock64:~/Desktop$ sudo mount -t auto /dev/mmcblk1p1 /mnt/SD
When you say the distro is Armbian, is this the Armbian Debian desktop release that you're running? As if it is, it has nothing to do with ayufan. Just want to clear that up.
RE: can a SD card be used as storage with emmc boot - by pfeerick - 05-03-2018, 04:03 PM
Question Compatible eMMC modules and benchmarks danboid 7 21,322 03-09-2023, 08:14 AM
Last Post: arvendui
  DAC (ES9023) addon card on other SBCs like rpi? AlexS 1 3,925 08-28-2021, 04:53 AM
Last Post: CounterPillow
  RS-485 CAN HAT Rock won’t boot gnvdude 1 4,368 01-10-2021, 05:15 PM
Last Post: as365n4
  Help! Rock64 won't boot anything! trohn_javolta 3 8,992 03-09-2020, 06:03 PM
Question Have eMMC adapter - but can't seem to fix eMMC card SirRyanTheGeek 3 9,550 05-04-2019, 04:19 AM
Last Post: burito111
  Boot from M.2/USB 3 Max_H 8 14,665 05-03-2019, 02:56 AM
Last Post: Monstercrunch
  emmc module help default_user8 1 4,214 04-05-2019, 07:19 PM
Last Post: SirRyanTheGeek
  Boot on power-up vicencb 1 4,126 11-26-2018, 11:45 PM
Last Post: evilbunny
  Dead eMMC? machina 8 13,224 11-21-2018, 05:05 AM
Last Post: machina
  FORSEE eMMC is reliable? ramprasad 3 7,373 11-12-2018, 03:34 PM
Last Post: Tortax
