can a SD card be used as storage with emmc boot
(04-28-2018, 08:54 PM)evilbunny Wrote: SPI is so you can boot from a USB device, EMMC always boots first with or without SPI, although the sdcard may sometimes seem to boot first because partition names are used in /etc/fstab.
USB or PXE (network) :-P
But yes, indeed, eMMC wins the race at boot if you don't flash the SPI, unless you use the jumper to hobble it. Wink
The issue with partitions in /etc/fstab is a good reason to use UUID references instead, then there is no confusion.
RE: can a SD card be used as storage with emmc boot - by pfeerick - 04-28-2018, 09:02 PM
Question Compatible eMMC modules and benchmarks danboid 7 21,322 03-09-2023, 08:14 AM
Last Post: arvendui
  DAC (ES9023) addon card on other SBCs like rpi? AlexS 1 3,925 08-28-2021, 04:53 AM
Last Post: CounterPillow
  RS-485 CAN HAT Rock won’t boot gnvdude 1 4,368 01-10-2021, 05:15 PM
Last Post: as365n4
  Help! Rock64 won't boot anything! trohn_javolta 3 8,992 03-09-2020, 06:03 PM
Question Have eMMC adapter - but can't seem to fix eMMC card SirRyanTheGeek 3 9,550 05-04-2019, 04:19 AM
Last Post: burito111
  Boot from M.2/USB 3 Max_H 8 14,665 05-03-2019, 02:56 AM
Last Post: Monstercrunch
  emmc module help default_user8 1 4,214 04-05-2019, 07:19 PM
Last Post: SirRyanTheGeek
  Boot on power-up vicencb 1 4,126 11-26-2018, 11:45 PM
Last Post: evilbunny
  Dead eMMC? machina 8 13,224 11-21-2018, 05:05 AM
Last Post: machina
  FORSEE eMMC is reliable? ramprasad 3 7,373 11-12-2018, 03:34 PM
Last Post: Tortax
