can a SD card be used as storage with emmc boot
(04-28-2018, 06:11 AM)KeithJohnAlger Wrote: If you flash SPI then it should attempt to boot from the EMMC first, but without it flashed it will boot from the SD first IF THE SD IS MARKED AS BOOTABLE.  Which is very useful if you want to use it to make an image of your live system from the EMMC.
SPI is so you can boot from a USB device, EMMC always boots first with or without SPI, although the sdcard may sometimes seem to boot first because partition names are used in /etc/fstab.
RE: can a SD card be used as storage with emmc boot - by evilbunny - 04-28-2018, 08:54 PM
Question Compatible eMMC modules and benchmarks danboid 7 21,322 03-09-2023, 08:14 AM
Last Post: arvendui
  DAC (ES9023) addon card on other SBCs like rpi? AlexS 1 3,925 08-28-2021, 04:53 AM
Last Post: CounterPillow
  RS-485 CAN HAT Rock won’t boot gnvdude 1 4,368 01-10-2021, 05:15 PM
Last Post: as365n4
  Help! Rock64 won't boot anything! trohn_javolta 3 8,992 03-09-2020, 06:03 PM
Question Have eMMC adapter - but can't seem to fix eMMC card SirRyanTheGeek 3 9,550 05-04-2019, 04:19 AM
Last Post: burito111
  Boot from M.2/USB 3 Max_H 8 14,665 05-03-2019, 02:56 AM
Last Post: Monstercrunch
  emmc module help default_user8 1 4,214 04-05-2019, 07:19 PM
Last Post: SirRyanTheGeek
  Boot on power-up vicencb 1 4,126 11-26-2018, 11:45 PM
Last Post: evilbunny
  Dead eMMC? machina 8 13,224 11-21-2018, 05:05 AM
Last Post: machina
  FORSEE eMMC is reliable? ramprasad 3 7,373 11-12-2018, 03:34 PM
Last Post: Tortax
